engine heating up past idle >
Old 07-09-2011 | 07:39 PM
Default engine heating up past idle
I have 454 mpi overheating as soon as you get the engine past idle. I am thinking impeller any other ideas before i tear into it thanks
busto is offline
Old 07-09-2011 | 08:23 PM
Check for water flow thru the transom. If it's and older boat it could be restricted.
smcser is offline
Old 07-09-2011 | 08:34 PM
It is a 1996 baja 302 with bravo1's
busto is offline
Old 07-10-2011 | 12:34 PM
Impeller is the first thing to check.
Griff is offline
Old 07-10-2011 | 08:23 PM
It was the impeller.got it out of the water today and there was nothing left of the impeller.it was replaced last year so wondering why it was destroyed other engine is running at 150 to 160 degrees thanks for the help
busto is offline
Old 07-10-2011 | 08:39 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
make sure you got all the missing peices.
should have lasted more than 1 yr.... dry starts??
US1 Fountain is offline
Old 07-10-2011 | 09:12 PM
No dry starts,back flushed cooler and got some pieces out,wandering about thermostat and any other components or will the small pieces make it out the exhaust
busto is offline
Old 07-11-2011 | 01:13 AM
99% will get get caught by the oil cooler. Anything smaller will just pass all the way through the system. Pull the hose where water enters the oil cooler and check for debris.
Griff is offline
Old 07-11-2011 | 07:20 AM
I will do that today. THANKS for your help
busto is offline
