Timing Chain vs Timing Gears
I personally have not. What we are saying is...most people who have built motors (street cars, drag, circle track, boats, etc.), and have done the research...dont use gear drive set-ups. It's a known and proven fact about the vibrations/harmonics transfered throughout your entire cam/valvetrain with a gear drive. Look at it this way...with a gear drive...the crank is actually DIRECTLY driving the cam...which is driving the rest of the valvetrain. Any vibrations...harmonics...tremors...or bumps and thumps, are being sent to the top end of your motor. The roller chain acts like a buffer...or absorber in the system. It's basically healthier for the rest of the system. Especially in a boat motor.
I use a millodon BBC one..on a 600 CI 800+ HP N/A 10:1 engine..with absolute no problems !!!!!
I was just curious because we've been running the Milodon gear drives in our boats since the late 90s and I can't say they've ever caused a problem. We ran the Cloyes hex adjust prior to the gear drive and other billet stuff before that. The only thing I can say for sure about the gear drive, it takes a long time to wear out and the timing doesn't jump around at all. The gear drive is probably over kill if you're not running a solid roller.
