HP500 procharger..how much boost ? >
Old 08-02-2011 | 07:01 AM
Default HP500 procharger..how much boost ?
current setup, stock HP500 +.030, & lightning headers, procharger M3SC, prosystems custom blow thru carb, MSD digital 7 box w/timing retard and alcohol/water injection, remote intercooler...how much boost would you consider safe to run on 93 octane ? right now making 4psi @ 5200, thanks Rob
ezstriper is offline
Old 08-02-2011 | 11:43 AM
I run my M1 at 7 psi , work's good there and is relatively safe .
Jeff P31 is offline
Old 08-02-2011 | 01:55 PM
swan2's Avatar
I run my stock 502mpi m1 procharger @7psi turning 5500rpms.
swan2 is offline
Old 08-02-2011 | 08:54 PM
What's your static compression, 8.5-8.75ish? 7 lbs is no problem with just the intercooler, with the Meth 10-12 would still be safe. They like a fair bit of timing even with decent boost, don't go too conservative with your boost retard.
HaxbySpeed is offline
Old 08-02-2011 | 09:40 PM
I would say right around there....stock replacement J&E forged psitons, no head work and std .039 felpro marine gaskets..at the current 4 psi @ 5200 not using injection or timing retard. has a 5" blower pulley now...procharger says a 4.25 pulley will add 3-3.5 psi or a 4.13 4-4.5...so just trying to figure what works...
Old 08-02-2011 | 09:56 PM
Turbojack's Avatar
You should be able to run at least 7 lbs of boost, 30 degrees of timing & 93 octane. Make sure you have carb adjusted rich enough. What size intercooler are you running?
Turbojack is offline
Old 08-02-2011 | 10:14 PM
Procharger techs don't know $hit...........I run a 4.25 pulley, 454Mag (slightly worked) with the M1SC and I get 5+psi and I run 89 fuel....fair enough, MPI as opposed to N/A but, touch wood, I have had zero problems after some help from a couple of site members who know Procharger set ups inside out.....
As pointed out, keep your timing conservative and even 91 octane would be fine to run IMO.......
FogduckerIII is offline
Old 08-03-2011 | 08:56 AM
Scarab28's Avatar
+2 with 7 lbs boost, 30 degree timing, I'm running M-3 with 3.70" PC Pulley creating 7 lbs boost on 540 - no issues knock on wood.
Scarab28 is offline
Old 08-03-2011 | 03:00 PM
not sure on intercooler size ?? it's a remote all on the boat...was set up for EFI, I changed engines and switched to carb...
Old 08-03-2011 | 03:56 PM
7lbs...30 degree timing...plugs on the cool side....
MrSneakAttack is offline
