Hydro vs solid cam >
Hydro vs solid cam
Hydro vs solid cam
Old 08-14-2011 | 02:24 PM
fireboatpilot's Avatar
RIPSTA Racing Team
700hp on hyd. rollers no issues!
fireboatpilot is offline
Old 08-14-2011 | 03:28 PM
GPM
Flat tappet cam solid or hydraulic you might want to run a ZDDP additive.
GPM is offline
Old 08-14-2011 | 04:07 PM
Hydraulic roller camshafts work great at 5800 rpm but the secret is to carefully match the camshaft with the valvesprings. Not to stiff or to soft! Follow the camshaft manufacturers instructions exactly.
Go with Comp Cams and you will be good.
Dennis Moore
Dennis Moore is offline
Old 08-14-2011 | 05:52 PM
I find Comp's spring specs to be a little soft most of the time for an endurance application. I haven't had any issues spinning Morel hydro rollers 6000+ with .600"+ cams. I agree, it's all about matching your components and the Morel lifters will take the spring pressures needed to spin that rpm. excal82, I would in no way ever recommend a flat tappet cam but if that's what you're stuck with the solids would be the way to go for your app.
HaxbySpeed is offline
Old 08-14-2011 | 06:57 PM
Thanks Haxbyspeed! this engine will get a hydro roller this winter from Bob,rmbuilder but as of now im trying to finish up the summer with a inexpensive flat set-up but still make a little HP. solid flat $225 and use my springs i have now. hydro roller $1500 with springs! i just want to go boating
excal82 is offline
Old 08-14-2011 | 07:18 PM
GPM
GPM is offline
Old 08-15-2011 | 08:22 AM
spin my hydraulic setup with .647 lift to 6000rpm all the time with no issues.
I have a giant used solid roller cam with solid lifters and pushrods if you are still thinking about a solid cam. Might be too big for your setup though. .697 lift, 262/272 duration @ 0.050
Philm is offline
Old 08-15-2011 | 08:59 AM
From what I see, most setup's run hyd, roller these days, running 5500 - 6500 rpm's. I don't even think Eddie Young, TCM and the other custom builders use solids in their 1100-1200+ hp motors, unless they go really big with 1400-1500+ hp. I've read that YPM also converts the "big" (very relative now a days) 850-1200 Merc's from solid to hydraulic.
Last edited by A.O. Razor; 08-15-2011 at 04:14 PM. Reason: Just thought of something.
A.O. Razor is offline
Old 08-15-2011 | 10:40 AM
That is true A.O. Razor.
The builder who installed this cam in my engine also built a pair of 1350's with methanol injection that spin to 6200rpm all the time with the exact same lifter/cam combo. Both were still going strong at 300 hours and never had the valve covers off. Pulled them last year because leak downs were getting higher than he liked.
Philm is offline
Old 08-15-2011 | 05:12 PM
Well going with solid roller this time more rpm more HP more speed. The key is putting on jessel pro shaft rockers should only have to touch one time a season. Live in north IL so we only boat about 4 months out of the year.
Skydog
skydog is offline
