-   -   Bottom Paint ermoval (https://www.offshoreonly.com/forums/general-q/261430-bottom-paint-ermoval.html)
aven2rus 08-31-2011 11:56 AM
Read through the posts I could find and some promised feedback they never posted so looking for some on different strippers.
Bought the boat from original owner and the bottom was not sanded prior to paint at his request so the gel should be decent under it. As you can see most has found its way off on its own.
http://i1201.photobucket.com/albums/...mPaintDay1.jpg
http://i1201.photobucket.com/albums/...50LeftDay1.jpg
Carbon Footprint 08-31-2011 04:09 PM
You'll never get a perfect finish with stripper alone.
Sand....sand.... Sand..... Wet sand.....compound....polish....
Wax..... Done!!!!
It doesn't look that bad, I'd hit it with a DA with 320 then wet sand 800/1000/1500 then compound and done
PARADISE ISLAND 08-31-2011 04:12 PM
Easy off oven cleaner!?
cliff_m_b 08-31-2011 07:06 PM
Try to find someone how performs soda blasting in your area, inexpensive, quick turn around time and very good results.
US1 Fountain 08-31-2011 07:25 PM
That worked for me. Working on a 2x2 section at a time......Sprayed it on, waited a couple minutes, couple swipes with a soft brushed, rinsed it right off. Every last spec washed right off. Just be sure you don't get the cleaner on your skin. Chit'll eat your skin right off!
aven2rus 08-31-2011 07:33 PM
Well It can't hurt to start with this in a spot and see what happens.
Anythign I get off will help reduce cost at my local gel coat shop. Got alot off tonight with power washer.
US1 Fountain 08-31-2011 08:03 PM
Yep, I pressure washed as much as I could while outside. In the areas where the paint was still thick once on blocks, I'd scraped alot off with a paint scraper so the cleaner would work easier. The paint just turned to water when lightly scrubbed after sprayed with the Easy Off. Wiped it down with a wet sponge, rinsed, then on to the next spot. I think I used 6 cans for my boat. Yours looks like it will be a peice of cake from as thin as it is, if the cleaner works for you. Might depend on the type of paint. As I said, keep it off your skin. Glove up and wear eye protection
InstaGator 09-17-2011 08:46 AM
Snowbowl toilet bowl cleaner works as good without the damages to your skin.
Pismo10 09-17-2011 07:25 PM
Does it really? That is a surprise.....
Crashbenefits 09-29-2011 11:50 AM
find a good automotive paint stripper it wont hurt the gelcoat
