Oil With Zinc >
Oil With Zinc
Oil With Zinc
Old 09-12-2011 | 07:52 PM
mcollinstn's Avatar
In recent years, most all of the previous oil formulations have undergone a "de-zinc-ing" including MANY popular "racing" oils. Kendall held out the longest, but nowadays the ZZDP content of even that has dropped under 1100ppm.
Brad Penn is probably the best oil for the money, if you have a special application.
BUT, if you have a roller tappet motor, and you are oiling thru the pushrods, and you are setup with "tight" bearing clearances and reasonable valvespring pressures - then you probably don't need a mega-zinc oil.
Just my thoughts.
MC
mcollinstn is offline
Old 09-12-2011 | 10:07 PM
GPM
Originally Posted by 07DominatorSS
I was told by Dave Crower to stay away from synthetic oil with my solid roller.
GPM is offline
Old 09-13-2011 | 06:47 AM
Why? That doesn't make any sense.
07DominatorSS is offline
Old 09-13-2011 | 06:59 AM
Originally Posted by Craney
Is oil with zinc good for roller cams? I'm thinking about changing to Kendell 20-50 with zinc.
All good replys!!!!
but whats the answer to the original question???
boatnt is offline
Old 09-13-2011 | 07:05 AM
Originally Posted by boatnt
All good replys!!!!
No best answer. Oil threads always get a lot of good info and a lot of different opinions. You have to put together all the feedback from people who know about this stuff and draw your own conclusions. My conclusion to your original question is yes, zinc is good in a roller engine but not necessary. I just put high zinc Kendall 20w50 in my 525.
thirdchildhood is offline
Old 09-13-2011 | 11:42 AM
Originally Posted by hondahp4
brad penn may not use 100% pa crude anymore, but its still a local company that i'm all for supporting. the more us based raw materials and us based companies i can support, the less we rely on foreign support.
hondahp4, I am guessing by your board name that you either ride a motorycle, really like oil, or both.
FWIW, Honda HP4 and other lubes by Honda are (at least they were a while back) blended and packed by Idemitsu Lubricants America Corp. They were called Apollo-American before changing to their corporate owners whose name is Idemitsu Kosan Co., LTD.
You may want to change your board name, oil brand, or both.
Ken
minxguy is offline
Old 09-13-2011 | 11:51 AM
My next oil change I'm going to try the Amsoil Z-rod.
CC230 is offline
Old 09-13-2011 | 12:12 PM
Originally Posted by cubicinches
VV855 is the part number for Valvoline Racing 20W-50 full synthetic. Excellent product.
I know. I run the 851. SAE oil, 20w-50. At the intervals i change my oil, I dont see the point in spending the extra money for the synthetic.
Philm is offline
Old 09-13-2011 | 04:12 PM
GPM
Use of Synthetic Oils
Crower does not recommend the use of synthetic motor oil in any application, particularly in hydraulic and flat tappet camshafts. If your car manufacturer's owners manual suggests running synthetic oil, you may do so. The minimum gains in horsepower are offset by the excessive wear to cam and lifter surfaces. We have found that the benefits, of synthetic motor oil, do not outweigh the costs and may endanger your engine's life. Crower recommends a non-detergent / race only petroleum based 30wt. motor oil in all performance applications. The lack of phosphorus and zinc in current oil blends is catastrophic to engine longevity. For all applications we do recommend running our ZDDPlus additive, which adds zinc and phosphorus back into the oil.
GPM is offline
Old 09-13-2011 | 04:30 PM
Synthetic oils are by far superior to petroleum products. Yes, they do cost more, but provide much more protection, quicker lubrication at start up, cooler operating temps, which means less friction, therefore increased horsepower and reduced wear. They last longer, typically 2-3 times longer. You just have to make sure you have an oil fortified with Zinc still. Yes, thats what the AMSOIL Zrod is made for, along with the other two links I posted. There isn't a NASCAR team that runs petroleum, and I'm pretty sure those motors all have rollers and flat tappets.
