thunderbolt 4 ign problem >
Old 09-11-2011 | 04:59 PM
Default thunderbolt 4 ign problem
engine is a blown 355 merc dist, thunderbolt 4 ign, engine cranks but no spark, if i tap the wht grn to ground it will fire the coil, tried 2 diff dist same problem no spark, i hooked up my spare dist to the wiring and spun the dist over with a drill no fire or tach sig at dash,tach stays at 0
any ideas
thanks
b18cls1 is offline
Old 09-11-2011 | 05:07 PM
Did you try replacing the coil ? Kill switch lanyard ? (sometimes they get bumped, and then the motor wont fire).
tinman565 is offline
Old 09-11-2011 | 05:19 PM
swapped coils first and kill switches in place, plus if i manualy ground the coil it will fire
need to know how to test the tb4 system
b18cls1 is offline
Old 09-11-2011 | 05:33 PM
any ideas
thanks
did you have the distributor grounded?and have you tried the dist module?
ext2gtx is offline
Old 09-11-2011 | 05:51 PM
waybomb's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Active Streak: 90 Days
Send me your email address in a pm. Monday evening I'll send you two pdf's, one a flow chart for troubleshooting, and the other with detailed troubleshooting procedure.
waybomb is offline
Old 09-11-2011 | 06:21 PM
i just got it running clead off the corrosion on the rotor where it hooks to dist shaft and now it fired right up
thanks
b18cls1 is offline
