Dyno correction factor in Colorado >
Old 10-03-2011 | 03:16 PM
  #211
Originally Posted by Zone 5
I post the top, and you quote it and post below it? WTF are you smoking?
Its Ok Doug, Its perfectly fine to be a follower.
cstraub is offline
  #212
Originally Posted by cstraub
Doug,
Your funny. I am helping them right now with purchasing a new dyno. I can see why you are the way you are if you treat people like a number.
I'd like to see you get an open account with a MFG.
sure you are. and you work FOR stef, and you actually own the machines that make parts that you claim to sell.
Just because most of the people you sell parts to are deadbeats or unemployed with no credit doesn't mean we all are.
Zone 5 is offline
Old 10-03-2011 | 03:23 PM
  #213
I speak to the Shaws quite often. Nothing wrong with combos the customer got and your right, Shaws work impressed someone as they wanted to send another set of heads down to be duplicated. Shaw may be from the south, but he wasn't born yesterday. Jeremy and I had quite the conversation over the whole matter. And yes they are still customers.
Not many believe, hmmm, I don't think it is my looks that keep booking work.
I don't think when you are OPEN account NET 30 it is a back door deal.
I'll bet you did have quite the conversation with Shaws.
Bad spin job Chris.... Yes there was a problem with the "combo". The problem was with the cam part of the "combo", your cam, you may not have known it because you're cam challenged. However, obviously Shaw was aware of the cam problem. There was no problem with the heads, as I mentioned.
I'll just bet Shaw is a big customer of yours.
Your looks not booking work? That I can identify with LOL
So, no more back door deals?
Kidnova is offline
Old 10-03-2011 | 03:41 PM
  #214
Tell me when you aquire that open account.
cstraub is offline
Old 10-03-2011 | 03:43 PM
  #215
All the boat engines Shaw has done I have done the cams for.
cstraub is offline
Old 10-03-2011 | 04:19 PM
  #216
we know. and it blew up because you F'ed the cam up.
Zone 5 is offline
Old 10-03-2011 | 04:21 PM
  #217
SB
Anybody think this "Does not NEED ECU Programming" when installed in 502MPI's ?
Grind: CBH276/286-14HR
Intake Lobe / Exhaust
#HR276/378 / #HR286/350
276* at .006” / 286* at .006"
224* at .050" / 231* at .050"
.643” w/1.7 rockers .595” w/1.7 rockers
Lobe Type CTS / Lobe Type: CRA
Torque Lobe / RPM Lobe
See Below
Lobe Type explanation:
• The first letter is either "C" for a conventional shaped nose on the lobe, or "D" for a dwell nose. Dwell lobes are often used when there is a lift rule, such as NHRA stock classes. Dwell lobes are usually not well suited for higher RPM applications.
• The second letter is either "R" (RPM) for lobes suited for higher RPM applications or motors with numerically high rocker ratios, or "T" (Torque)for lobes suited for lower RPM or motors with numerically low rocker ratios.
The third letter is either "S" for symmetrical lobes (opening and closing ramps the same), or "A" for asymmetrical lobes (opening and closing ramps different). Asymmetrical lobes usually have a slower closing rate to help prevent valve bounce.
I know the engines/ECU's rejected it and cost someone big moolah and lots of time.
Could he call you Straub and get his money back ? More than just the cams ?
SB is offline
Old 10-03-2011 | 04:56 PM
  #218
Have him call me Scott.
cstraub is offline
Old 10-03-2011 | 05:01 PM
  #219
gonna give him his money back? Be a man. Its the right thing to do. If so, say so. Other wise why would anyone waste their time calling you?
Only a totally disfunction person would change the cam in a 502 Mag EFI without telling the customer that it needs to be reprogrammed.
Zone 5 is offline
Old 10-03-2011 | 05:11 PM
  #220
People have trouble remembering when they make things up.
Sounds like you are more guilty than anybody.You tell a blatent lie about Billy and those canfield heads.
Well news flash,Tom told me today heads were hard anodized and that they dropped a valve and messed up a guide or 2.So your words of monkey porting is total bs when it comes to those heads.Nice try
As for professionalism,call canfield and telling him a lie about Billy is just plain low.
shaun harrington is offline
