Dyno correction factor in Colorado
#241
Originally Posted by Cstraub
09/16/11 My bread and butter is the parts I make. Cams have been a passion of mine for many years. I use a DOS based program that I created in college and it spits out lobe area. When it comes to cams I don't have a sell any, it's enjoyment to me and since it is that my customer enjoy one on tech and excellent results.
Program from back in 1988.....tells you what lobes from Bullet in 2011 to use......
Then, this year you won't answer on performance boats to your bodyguards that this program exists.
Also, if by say you do have a program that spits out lobe area, surely you can't go to the Bullet Cam Catalog (which you use) to find lobes with the same lobe area. How can you know the lobe area off of just seat, .050" duration, .200" lobe duration, and max lift ? That's just three duration vs lift points. Lobe area ? Don't think so !
#242
Another site that is going to get taken. Notice the way, just as he won't answer OUR questions, that he ignored the request to be a paid sponsor to sell stuff, yet he kept on trying to sell it.
#243
What I thought would be a quick Google search ended up being an extremely long one.
So.......if Cstraub ever tells someone that their business must be slow because of the posting they do, fell free to cut and paste the foolowing sites I found he is a member on....pimping products.
This will truly show how his business is set up. BTW: the links attached to each forum name is just proof he is a member there. I did not spend the time finding 'juicy' threads, although some probably are and some that I saw are I have put a remark under the link.
Here you go Chris.............if you are going to accuse me in front of people about having slow business.........I'll just cust and paste the below.
=============Cstraub Forum List==============
offshoreonly.com - obviously
http://www.offshoreonly.com/forums/g...-budget-3.html
460ford.com -
http://www.460ford.com/forum/showthr...883#post858883
M3Forum.net -
http://www.m3forum.net/m3forum/showthread.php?t=15442
camaros.net -
http://www.camaros.net/forums/showpo...2&postcount=24
nastyz28.com -
http://nastyz28.com/forum/showpost.p...8&postcount=25
3800pro.com -
http://www.3800pro.com/forum/cams-he...html#post12583
Cam guy for these engines disagrees.
seadooforum.com -
http://www.seadooforum.com/showthrea...ll=1#post56760
dartheads.com -
http://www.dartheads.com/dartboard/s...9&postcount=10
hardcore50.com -
http://www.hardcore50.com/vbulletin/...02&postcount=9
boatfreaks.com -
http://www.boatfreaks.org/forums/sho...4&postcount=12
hotrodders.com -
http://www.hotrodders.com/forum/eval...tml#post354225
10/21/2004 Cstraub - My figures HP and Torque figures are a by product of designing the right cam and consiquently always low. Guess you can't get everything for 20K in programing.
Chris
Chris
http://ls1tech.com/forums/14128199-post10.html
We ?
riverracer.net -
http://www.riverracer.net/forums/sho...560#post895560
Should call Vortec pro as he builds pump gas 454's for the price of these heads. Interesting post Chris. And you guys agree with each other ?
7/06/07 Cstraub -
I have a customer that builds engines for a pull truck class limited to 470CID, flat tappet cams, and a 4150 modified carb. He has 2 customers with 049's that are making 690 and 715 HP at around 7800 rpm. Now these are 20K OEM headed engines with $4K of extensive port work including welded and reshaped ports. In addition these engines have 14.5 and 15 to 1 compression with custom chamber matched pistons.
http://www.trifive.com/forums/showpo...60&postcount=2
Don't take this as legit info.
speedtalk.com -
http://speedtalk.com/forum/viewtopic.php?t=23668
Another forum he made a new thread for the snakeoil 23hp for $.60 .
teambajamarine.com -
http://www.teambajamarine.com/forum/...ad.php?t=12850
seriousoffshore.com -
http://seriousoffshore.com/forums/sh...8&postcount=31
still thinks he works at Stef's. LOL. Year 2010.
stevenovasite.com -
http://www.stevesnovasite.com/forums...3&postcount=17
Corral.net -
http://forums.corral.net/forums/5-0-...fters-rpm.html
performanceboats.com -
http://www.performanceboats.com/dyno/76225-23-hp-about-$-60-a.html
CamaroZ28.com -
http://www.camaroz28.com/forums/member.php?u=673
Induction designer too ?
NMRA (Ford National Series) . com -
http://www.nmradigital.com/forums/member.php?u=5765
chevyteam.com -
http://www.chevyteam.com/forums/show...21&postcount=1
348-409.com -
http://www.348-409.com/forum/index.p...47/#post-46902
chevelles.com -
http://www.chevelles.com/forums/showthread.php?t=334382
ls1gto.com -
http://www.ls1gto.com/forums/member.php?u=2139
corvetteforum.com -
http://forums.corvetteforum.com/memb...5-cstraub.html
speedwake.com -
http://www.speedwake.com/forums/showthread.php?t=36081
motorsportsvillage.com -
http://www.motorsportsvillage.com/fo...php?f=5&t=2029
firstgenmontecarlo.com -
http://www.firstgenmc.com/ubbthreads...0&page=all#top
clubcobra.com -
http://www.clubcobra.com/forums/smal...tml#post394439
Just came upon this during a search and thought I would add some insight - Cstraub.
1320techtalk.com -
http://www.1320techtalk.com/viewtopic.php?t=246
tcnw racing.com -
http://tcnw.activeboard.com/t4466444...rt=newestFirst
yellowbullet.com -
http://www.yellowbullet.com/forum/sh...d.php?t=293405
I'm sure more..............................
Edit in: More sites he's in
chevelledrivers.com -
http://www.chevelledrivers.com/Cstraub
#244
Okay. Just called your bluff. Man, oh man, I knew you where all over the place and use the internet mostly to pimp your stuff, but I was not expecting this.
460ford.com -
M3Forum.net -
camaros.net -
nastyz28.com -
3800pro.com -
seadooforum.com -
dartheads.com -
hardcore50.com -
boatfreaks.com -
hotrodders.com -
ls1tech.com -
We ?
riverracer.net -
trifive.com -
speedtalk.com -
stevenovasite.com -
Corral.net -
CamaroZ28.com -
chevyteam.com -
348-409.com -
chevelles.com -
ls1gto.com -
corvetteforum.com -
speedwake.com -
clubcobra.com -
LOL.
1320techtalk.com -
tcnw racing.com -
yellowbullet.com -
460ford.com -
M3Forum.net -
camaros.net -
nastyz28.com -
3800pro.com -
seadooforum.com -
dartheads.com -
hardcore50.com -
boatfreaks.com -
hotrodders.com -
ls1tech.com -
We ?
riverracer.net -
trifive.com -
speedtalk.com -
stevenovasite.com -
Corral.net -
CamaroZ28.com -
chevyteam.com -
348-409.com -
chevelles.com -
ls1gto.com -
corvetteforum.com -
speedwake.com -
clubcobra.com -
LOL.
1320techtalk.com -
tcnw racing.com -
yellowbullet.com -
#248
http://www.hotrodders.com/forum/dyno...tor-29928.html
12-11-2003, 09:27 AM
Cstraub
Member
Wiki Edits: 0
To many variables in that to be monitored with
out a real life dyno. Any software would be a guess. I use
a custom piece I had designed some years ago
to the tune of $20K and its HP numbers are very conservative
for what my customers alky engines run.
An educated guess will be as close.
Cstraub
Cstraub
Member
Wiki Edits: 0
Cstraub
#249
460ford.com -
M3Forum.net -
camaros.net -
nastyz28.com -
3800pro.com -
seadooforum.com -
dartheads.com -
hardcore50.com -
boatfreaks.com -
hotrodders.com -
ls1tech.com -
We ?
riverracer.net -
trifive.com -
speedtalk.com -
stevenovasite.com -
Corral.net -
CamaroZ28.com -
chevyteam.com -
348-409.com -
chevelles.com -
ls1gto.com -
corvetteforum.com -
speedwake.com -
clubcobra.com -
LOL.
1320techtalk.com -
tcnw racing.com -
yellowbullet.com -
460ford.com -
M3Forum.net -
camaros.net -
nastyz28.com -
3800pro.com -
seadooforum.com -
dartheads.com -
hardcore50.com -
boatfreaks.com -
hotrodders.com -
ls1tech.com -
We ?
riverracer.net -
trifive.com -
speedtalk.com -
stevenovasite.com -
Corral.net -
CamaroZ28.com -
chevyteam.com -
348-409.com -
chevelles.com -
ls1gto.com -
corvetteforum.com -
speedwake.com -
clubcobra.com -
LOL.
1320techtalk.com -
tcnw racing.com -
yellowbullet.com -
Holy Crap!! is this guy Sunkin's long lost brother????
#250
Seems the BS just got a lot deeper
Cstraub
Cstraub
