MEFI 4.. How much HP?? >
Old 09-28-2011 | 11:05 AM
CNC's Avatar
CNC
Default MEFI 4.. How much HP??
I will be converting my Procharged ...carbed to MEFI over the winter.
I am in Michigan and the water temp can be 72 one day.... get a offshore breeze next day 48 degrees, drive-ability sucks.
MEFI uses hi impedance injectors, only available up to 80 pounds. I am at 1100hp now, this should be doable
w/ 80's (http://www.rceng.com/technical.aspxl). But is any one building crazy hp w/MEFI? and what are they using for injectors?
Randy
CNC is offline
Old 09-28-2011 | 11:20 AM
Talk to Eddie young , he is heavy into the mefi systems .
575cat is offline
Old 09-28-2011 | 01:10 PM
Whipple Charged's Avatar
Randy
We've got 105lb/hr (@43psi) injectors, high impedence. We've made 1600+hp with the MEFI.
Whipple Charged is offline
Old 09-28-2011 | 01:19 PM
It was good talking with you CNC. The (8) -80's will do all that you need. Good luck and let me know if I can help.
Eddie
Young Performance is offline
Old 09-28-2011 | 08:02 PM
articfriends's Avatar
Bosch makes a 95lb Hi-z injector:
http://www.fuelinjectorconnection.co...&productId=214
and they are around now for 600$ a set. Only drawback is they use a ev-6 connector whearas your Mefi harness uses ev-1. There are adapters though fairly cheap.
As far as power, you can drive 10 injectors and there are custom 200lb hi-z injectors so theoretically you could support 3400 hp at 85% duty cycle on the injectors , Smitty
articfriends is offline
Old 09-28-2011 | 08:09 PM
MEFI will support up to 12 injectors, MEFI 4 will also support Peak/hold injectors or low impedence
tunertech is offline
Old 09-28-2011 | 08:12 PM
Yes, it sure will.
Old 09-28-2011 | 08:16 PM
What do you switch/change to run low impedance injectors, Smitty
Old 09-28-2011 | 08:23 PM
address (HEX) 0015 Bit 5.... KSYSCFGAIL. Can't post pics... not a premium member. What tools are you using
Old 09-28-2011 | 10:43 PM
You could also run a piggyback injector driver to run whatever and how ever many injectors you want.
Eddie
