mobil or amsoil >
mobil or amsoil
mobil or amsoil
Old 09-30-2011 | 08:01 PM
scottw's Avatar
Originally Posted by weldcrane
trying to figure out wich oil is better
Let me know if you choose Amsoil. Im a independent dealer.
www.lubedealer.com/s&wsynthetics
scottw is offline
Old 09-30-2011 | 08:06 PM
OldSchool's Avatar
Originally Posted by jeffswav
I use the 15/40 Amsoil marine/diesel oil.
Me too...for the last 5 years. Nothing has broke, so I'm staying with it!!!!
OldSchool is offline
Old 09-30-2011 | 09:00 PM
Amsoil in everthing
firehawkcat is offline
Old 09-30-2011 | 10:13 PM
Yea I am a dealer also, they make a oil or lube for almost anything......
jeffswav is offline
Old 10-01-2011 | 08:21 PM
they have 20w50 z rod oil now with high zinc. Ive always used there 15w40 diesel oil on stock motors and all my customers boats. heck i even use there 10w30 small engine oil in my garden tractor and it starts in 40 below canadian weather
zeke is offline
Old 10-02-2011 | 07:08 AM
i think amsoil has a new one out,replacing the 3000 series...havent seen it yet but its supposed to be 15w50...maybe the dealers can chime in...
pqjack is offline
Old 10-02-2011 | 07:19 AM
offshoredrillin's Avatar
I used mobil one v twin since my rebuilds in 08, i did them this year as my alum heads finally gave way. one cam had grooves in the lobe, im not saying this is from the mobil one as when the cams were bought in 07 crane had some cams that werent hardened enough. I just switched to amsoli v twin oil which according to all tests that i read surpassed mobil 1 v twin in every catagory including amount of zinc. have a few hours on it with the amsoil and really like the sound and oil pressure readings, if you close your eyes and just listen to the engines they sound smooth..ohh and wix/napa filters...just fyi i also found out that the standard 1060 filter from napa only flows 9 gallons per hour and the 1060R flows 28 gallons per hour.
offshoredrillin is offline
Old 10-02-2011 | 07:56 AM
I'm as guilty of this as anyone- I use Amsoil religiously- but can we all agree that a high quality synthetic has advantages over a standard oil, and which ever one you use is going to protect your engine better. Beyond that, what's the measurable benefit even if say Amsoil is better than Mobil 1- my rings are gonna last 10 more hours?
ctuck0659 is offline
Old 10-02-2011 | 08:15 PM
http://www.mobiloil.com/USA-English/...duct_Guide.pdf
http://www.mobiloil.com/USA-English/...t_Engines.aspx
Jeff
hallj is offline
Old 10-02-2011 | 08:20 PM
How does the filtration efficiency compare between the two filters?
Is one gravel strainer compared to the other?
Jeff
hallj is offline
