Mounting trim tabs - along bottom or horizontal?
That was my thought as well.
In my opinion, looking at the superboat pic from Dave M the tabs are way high above the bottom of the hull and would have to be at a steep down angle to even touch the water.
They may have worked good that way on his boat but on mine I dont think it would have been as effective.
Also, if mine did not have the extra wide horizontal surface area on my strakes I may have opted for parallel to the hull..
I have heard there were some safety issues with a step bottom hull sliding/spinning out in a turn and catching a horizontal tab, making the situation worse.
My straight bottom hull shouldn't have that problem..
on my 24 outlaw, I have the biggest eddie marine kplanes you can buy, (equal to the 380s) I have them mounted vertical along the bottom of the boat, and its B.S. if you dont think those tabs wont contact the water at wide open. I can tab them all the way up and run my boat wide open, and trim it to the moon and they wont hit the water, and my boat rides really high in the water, but I have enough throw on the rams that I could stuff the nose in the water at wide open if I wanted too..I am scared to even hit those kplane switches at a good amount of speed cause they would grab so much water that I think I would spin the boat..
Any fast boat with parallel tabs will get very dangerous if you don't be careful with how you handle the tabs at speed.
Mine (Danas on the Squadron) are 5/8" above the bottom. The pic looks lower because the mount is lower than the tab.
When mine are up they will be completely out of the water and when they are lowered it won't take much negative to come in contact with the water.
Dana Recommends 1/4" above the bottom...
Notice these pics of my other boat how high it rides.
This boat had the 280s in the 'stock' parallel location.
I used the port tab to level me out from prop torque, I had to plant it quite a bit at high speeds to get it to even touch the water. (Pictured)
When I hit a wave the tab would be down too far and throw the boat to the stb side.
Also if it started chine walking, the tabs would rock from one side to the other, making the problem worse.
That is why I did what I did on the Squadron...
I have to run with the port side down some too..and it doesn't fly right off a wave...but I think the bravo 1 I'm running might have alot to do with it...I need to try a prop besides a bravo 1
I made some wood templates to do the drilling and get it at the 3/4" above the bottom of the hull. Used the k-plane back plate and a router table with a trim bit. Worked out good, the wood is a lot lighter and easier to tape onto the hull. Two layers of 3/4" plywood helps to keep the drill bit straight too. Kept the pilot holes at 1/4".
