-   -   Cam Upgrade ???? (https://www.offshoreonly.com/forums/general-q/264839-cam-upgrade.html)
goebel1 10-30-2011 08:27 PM
Originally Posted by brivander (Post 3539896)
Then I have no idea why you'd go flat tappet... You could get an off the shelf cam, or for a little more money call Bob here: http://www.marinekineticsonline.com/
You need to figure out your combination a little better before you pick a cam anyhow.
X2 call Bob you can get a custom cam for the same price.
brivander 10-30-2011 08:47 PM
Let me give a little explanation here, if you haven't ever talked to Bob before -- Bob is the best cam guy you'll find, plus he'll help you figure out a combination to stay in your budget. He'll help you all the way through the process and get you the motor that fits YOUR needs.
This is the FIRST phone call you should make, and once you do you'll understand. I had my heart set on going with a flat tappet cam in my 502 when I did my rebuild (it was a gen V, so it was a larger process to go roller) to save money, for right around $800 extra with some careful shopping, I turned my 420hp OMC 502 into a 540 hp motor that idles at 675rpm in gear...pretty amazing when my goal was 500hp. You already have roller...just make the phone call, you won't regret it.
innerrage 10-30-2011 09:27 PM
bob m is the cam guru , i am calling him tomorrow to build me a set for my smallblock,
DONZIminx20 10-31-2011 10:22 PM
DONZIminx20 10-31-2011 10:26 PM
So i did some research and yes, roller cams are better and it makes sense but what about lift, duration, lobe separation and rpm range ?? There's where Im stuck now..not sure which route to go. My plans are to eventually go with an edelbrock intake, holley 650 carb, msd ignition, and a descent exhaust. Also, right now the machine shop just did a .30 over with flat top pistons. I didnt want to do too much since I want to keep it as reliable as possible
brivander 10-31-2011 10:39 PM
You can listen on here to everyone tell you the best combination (probably their own) or dial this number, trust me, take 15 minutes to talk to him about what you want and your goals etc. He can walk you through the most cost effective way to get where you want to be. He will tell you the pro's and cons of everything you are wondering about, and the potential limitations of the parts you already have, what should be upgraded or what is just fine the way it is, he is NOT pushy at all. If you want reliable he will advise you on reliable.
I won't go and post his cam specs for my motor, but I can NOT believe the specs and the way it idles, runs, etc, I would have never believed it if I looked at the cam card. I would have called :bsflag:
In my experience (very limited) cams are an art, off the shelf cams will work fine but it may or may not match your combination of parts. This is my first and only custom cam, I will never again buy something off the shelf.
Bob -- 585.654.8583
fastestbowtie 10-31-2011 11:51 PM
I would also suggest calling Bob for cam advice since i have never seen anyone unhappy with his recommendations. That said I do not think i could ever be happier with a different cam than the one I have.
http://www.cranecams.com/product/car...detail&p=24208
It is an off the shelf Crane cam that was installed in my 355 when it was rebuilt in 1995. Made 424 HP and 445 Tq on an engine dyno through dyno headers with the stock Mercruiser 320 EFI induction, ignition, and ECU. My 20 ft boats runs 72+ with stock Merc exhaust manifolds with thru hull (under the swim step) exhaust. Idles between 500-600 rpms and has zero issues. Only problem I would see is getting those stock Vortec heads to work with the high lift (my 87 motor uses out of the box iron Dart heads).
DONZIminx20 11-01-2011 08:31 AM
Hey ppls, thanks for all the advice and tips. I will call bob this morning
n2ostroker 11-02-2011 12:13 AM
Sorry.. I looked up the 880 block and thought it was a non roller block. Being that it is a roller look at the GM "hot cam" and the beehive spring upgrade. There have been a few guys that have had good results with it. For a little more the guy mentioned above can get you a good custom grind that would give you great results.
DONZIminx20 11-03-2011 12:46 AM
hey guys thanks again for all the advise. I did some research as well and i did call the guru also but due to budget i had to go with a custom grind cam from competition cams. I called summit racing and the guys over there were extremely helpful and guided me to onto getting a marine custom grind cam. It had good lift and duration plus the lobe separation that i needed to go perfect with my setup. lets hope that i went the correct route...Next step is the Carb. Any suggestions ??
