removing tabulators 496Ho >
Old 01-02-2012 | 03:04 PM
my reasoning is...if you push more air in,try your best to get more air out,specially a 496 with its poor-flowing exhaust port...remove all the restriction you can...they do make more power without it....jmo
jack
pqjack is offline
Old 01-02-2012 | 08:18 PM
I removed mine on my old boat, and while it will theoretically make more horsepower, I didnt notice any "seat of the pants" or actual speed increase at all. If u enjoy working on ur boat and just feel like doing an improvement, then have at it! I used to do that when I was younger to my cars ie: taking the slack out of the throttle cable, making cold air intakes, etc . It was alot of fun then!
DirtyJerz is offline
Old 01-03-2012 | 04:41 AM
Thanks for all the replys .a mixed bag but the more i look at that small hole ,there comeing off and the internal flappers , as for working on cars and boats i allso did when i was younger , trouble is i still cant leave things alone . Can anyone tell me if all mec motors are fitted with tabulators if no, why the 496 ?? THANKS AGAIN regards paul
paul buckner is offline
Old 01-03-2012 | 07:41 AM
Wink
The turbulators are there to collect moisture than condenses in the riser after the engine is shut down and sits in the water for longer periods of time. The turbulators catch the dripping moisture and boil it off on startup. If you boat in salt water leave the turbulators in for sure. As for power gains Bob's numbers are good 8-10HP and as many have said here that does not translate to much in most boats. In a supercharged application the power gain would be larger at high rpms probably 20HP+ depending on the boost and build.
Best Regards,
Ray @ Raylar
Raylar is offline
Old 01-03-2012 | 07:46 AM
tony davis's Avatar
They used to be std fit on motors like the Bulldog with Gil manifolds and s/s risers.
tony davis is offline
Old 01-03-2012 | 10:42 PM
Originally Posted by checkeredpast
Anybody removed the turbulators on a procharged engine? Any water issues after removing?
Removed them from my set up and have had no issue's after 2 years .
Jeff P31 is offline
Old 01-04-2012 | 08:01 AM
Are these located where the riser bolts up to the manifold? how are they removed? Do they just pop out or do they have to be cut? I assume my 03 model 496 Mag has them as well.
bigredbaja is offline
Old 01-04-2012 | 09:00 AM
Knot 4 Me's Avatar
Part #16. You only need to replace one of the gaskets upon removal. You may want to have a new set on hand in case the old ones get dorked up when you remove the turbulators.
http://www.mercruiserparts.com/Show_...lbow+and+Riser
Knot 4 Me is offline
