engine mount dimensions >
Old 06-18-2002 | 11:11 PM
Official OSO boat whore
Default engine mount dimensions
I need to get the angle brackets cut to mount my engine on. If somebody could measure their boat, and get me some numbers I'd really appreciate it! What I need to know is the vertical distance from the transom (gimble) mounting pad down to the forward (side) mounting pads. This would be for a application that's using a factory isolation mount. I also need to know the distance (center to center) between the two forward mounts. These numbers don't need to be exact, just something to let me approximatly calculate where the mounts will be.
Cord is offline
Old 06-19-2002 | 08:41 AM
What? Nobody has a installed engine?
Cord is offline
Old 06-19-2002 | 09:36 AM
Scott's Avatar
Charter Member #30
Cord,
I just changed mine from the isolated mounts over to solid mounts. If you would of asked last week I could of got some dimensions If you have a old block try useing it to get your motors rigged in the right way. I do have all of my old aluminum angle brackets that your more than welcome to have. I even have the old mounts if you need them. Scott
I have Steps & Bubbles!
Scott is offline
Old 06-19-2002 | 11:29 AM
I ordered some solid mounts from Eddie that are in the same style as the factory ones. Hopefully these will be less likely to move around. Your offer for the angles is an intriging one! However, I must first determine the size of angle that I need. (ie 4" vs 6" vertical leg) Then we can talk $.
Cord is offline
Old 06-19-2002 | 05:06 PM
Common now! Can't anybody take a moment to measure their boat?
Cord is offline
Old 06-19-2002 | 08:12 PM
NASTY HABIT's Avatar
sorry .. volvo set -up here.....kinda quiet here this eve..
NASTY HABIT is offline
Old 06-19-2002 | 09:12 PM
Scott's Avatar
Charter Member #30
Who said anything about $ pay the shipping and they will be yours If you want I can take a picture and post it. If you can't use them I will give them to a friend that has a shop.
Scott is offline
Old 06-19-2002 | 10:26 PM
I appreciate the offer, no really I do! But I have to hold until I can determine the correct size. Guess that it's time for plan B. Wait, there is no plan B...
Cord is offline
superwrench0166
Drives and Lower Units
1
08-07-2007 08:34 AM
satisfactionII
Scarab
7
10-07-2006 12:49 AM
satisfactionII
16
07-15-2006 01:30 PM
SSComp
2
04-30-2004 07:18 AM
