Drive Gear Ratio >
Drive Gear Ratio
Drive Gear Ratio
Old 02-16-2012 | 11:05 AM
Default Drive Gear Ratio
I have a Bravo 3 upper with a 2.00 ratio, I want to install a lower unit from a bravo one X with a 1.5 ratio. What will be the gear ratio with the B3 upper and the B1 lower?
Recycle Perf is offline
Old 02-16-2012 | 11:41 AM
Yes that combo will work. Count teeth in top needs to be 32. Pull top cap off.
GTOFFSHORE is offline
Old 02-16-2012 | 01:04 PM
I was told with the 2.00 B3 upper, and the stock Bravo lower from a 1.5 drive, the drive ratio would be 1.5 on my new combo. Is that correct?
Old 02-16-2012 | 01:12 PM
correct
if it was a 2.20 upper w/ the b1 lower it would be 1.65
Itsallgood995 is offline
Old 02-16-2012 | 01:52 PM
Thanks boys
Old 02-16-2012 | 02:39 PM
t500hps's Avatar
21 and 42 footers
Originally Posted by Itsallgood995
correct
ditto.....
t500hps is offline
