Crankcase Cooler - Is there such a thing out there? >
Old 02-25-2012 | 12:03 AM
  #101
Rage's Avatar
Originally Posted by ICDEDPPL
Not if its been covered but just throwing it out there...
http://www.offshoreonly.com/forums/g...-vi-502-a.html
post #26
I changed mine from 11 psi to 25 psi for the offset bypass. The center is non functional because on the Gen 7 block the filter adapter bolt blocks that port completely.
Rage is offline
Old 02-25-2012 | 12:09 AM
  #102
Rage's Avatar
Originally Posted by Raylar
Rage:
Thank you for re-confirming that. Your'e welcome.The Melling HD/HV is the only pump we use and sell so oil pump volume you should have should not be the problem from an oil pump issue. Good to hear
Just to let you know we have a couple of customers running 750-800HP Whipple supercharged 496's that we built with thermostat oil cooler systems with coolers similar in size as yours and one is run at Havasu in over 110 degree temps for over three years now with lots of long distance and long duration blasts at 5000rpms and higher That is great. I can run all day at 5000rpm with no oil over temp issues as well. Different HP of course. It is the extra HP from the 5600-5800 rpm WOT that over heats the oil. with no oil overheating issues What is their crank case oil temp during extended WOT running?so I know its quite doable and possible when everything is right. I stll believe your issue may be plumbing, routing or compnent issues in your oil filter and cooler system and not bearing clearances. In that regard you were nice enough to send me two 25 psi oil bypass valves gratis to replace the stock 11 psi oil bypass valves at the block filter adapter back in 2008 when I bought a lot of parts from you and built the current motor. Is there any way that those were not the 25 psi units and were 11 psi units?
JMO
Best Regards,
Ray @ Raylar
Ray,
You did not tell us what the crankcase oil temperature was for the two Whippled 496 engines that you built that run WOT on Havasu.
Originally Posted by Rage
See above in red. Thanks.
Rage is offline
Old 02-25-2012 | 07:48 AM
  #103
Originally Posted by blue thunder
It seems your priorities are all wrong sir.
I agree, BT. I'm working on correcting that !!
Kidnova is offline
Old 02-25-2012 | 11:40 AM
  #104
Rage's Avatar
Originally Posted by SDFever
Here's the flow. I wonder if your builder changed the flow in or from the block and did not realize he caused an endless loop??? Maybe?? It could happen. See picture.
By the way I am the Builder.
My remote oil system routing remains identical to the stock Mercruiser 496HO remote oil system (example Mercruiser diagram and parts list attached).
Attached is your drawing with my oil system overlaid on it. As you can see my oil flow at the filter adapter is different from your representation because the Item #19 "FITTING, OIL FILTER ADAPTER" part number 862958 blocks the oil flow path that your diagram portrays.
When I get back and can take the pictures of my remote oil system that you have been requesting it will show this oil flow path. Similarly the sea water flow path through all the coolers is the same as the stock 496HO with one exception....the water flow direction through the oil cooler is against the oil flow direction.
Attached Thumbnails Crankcase Cooler - Is there such a thing out there?-496-oil-flow-routing.jpg
Rage is offline
Old 02-27-2012 | 12:55 AM
  #105
Number 16 is where my oil leaves the block. Not sure what you've done etc. Just showing you how it came stock with that adapter. If I'm understanding you and you say 19 blocks the flow,,,, that is the mounting hardware for the adapter plate. What you are saying does not sound right unless I've totally misunderstood you. 16 is supposed to be the exit. If it's not, then you have either done something else fancy with your plumbing or you are returning a significant amount of oil back to block with little cooling or filtration.
19 and 16 are effectively the same thing. One is plugged and the other is not but they are the same passage.
SDFever is offline
Old 02-27-2012 | 07:47 AM
  #106
Rage's Avatar
Number 16 is where my oil leaves the block. Then yours and mine are the same. Not sure what you've done etc. Just showing you how it came stock with that adapter. Incorrect, your diagram shows the oil flow going immediately back into the engine via the center bypass valve in the block which is not the way it flows for your and my engine ie it flows out of the oil filter adapter to the oil cooler. I'm understanding you and you say 19 blocks the flow,,,, that is the mounting hardware Correct......that blocks the oil's ability to flow back into the engine as your diagram portrays. for the adapter plate (ADAPTER, OIL FILTER" part number 862870T). What you are saying does not sound right It is correctunless I've totally misunderstood you. 16 is supposed to be the exit. That is what I am saying and my drawing overlay on you diagram portrays If it's not, then you have either done something else fancy with your plumbing or you are returning a significant amount of oil back to block with little cooling or filtration.Not the case.
19 and 16 are effectively the same thing. One is plugged and the other is not but they are the same passage.Yes, together they combine to direct oil flow out of the engine to the oil cooler.....and not as your diagram shows the flow going immediately back into the engine (through the #19 fitting which has no hole in it to allow this) w/o being cooled by the oil cooler. That is what your drawing portrays which I am disagreeing with because it is an incorrect portrayal of oil flow for my engine. It seems we agree on the correct oil flow path verbally and therefore it seems that we collectively agree that your diagram describing the oil flow path is in error as a description of your and, as I am telling you, my oil flow path
Comment above in red
Rage is offline
Old 02-27-2012 | 07:56 AM
  #107
Rage's Avatar
Rage:
JMO
Best Regards,
Ray @ Raylar
Ray,
ttt
Ray,
What it the max crankcase oil temperature that the two Havasu Whippled 496 engines you mentioned above experience when run extended WOT?
Rage is offline
Old 02-27-2012 | 11:25 AM
  #108
The highest oil temperature the customer ever related to me was that the oil would sometimes get to 240-250 degrees after hard WOT runs of longer duration and then would cool back down to the 180-190 degree range very quickly in a few minutes or so. With the synthetic 20-50w oils being used I do not think these are problem temperatures.
Best Regards,
Ray @ Raylar
Raylar is offline
Old 02-27-2012 | 12:12 PM
  #109
Best Regards,
Ray @ Raylar
And that engine is making what??? 800 hp? If it's the Magic (which I'm sure it's one of the boats you're talking about).
I saw the dyno runs. It's a flippin' beast @ 812 hp 5300 rpm.
SDFever is offline
Old 02-27-2012 | 12:52 PM
  #110
Rage's Avatar
Best Regards,
Ray @ Raylar
Thank you.
Rage is offline
