Crankcase Cooler - Is there such a thing out there? >
Old 02-23-2012 | 09:29 PM
  #91
Rage's Avatar
Originally Posted by SDFever
Here's the flow. I wonder if your builder changed the flow in or from the block and did not realize he caused an endless loop??? Maybe?? It could happen. See picture.
SDF,
Thanks for your effort to provide the diagram. Unfortunately the reduced size file that OSO accepted was illegible on my end when I printed it. I will PM you my email address. Please send the better resolution file to me there if you would. Thanks
Rage is offline
Old 02-23-2012 | 10:14 PM
  #92
Wink
Rage:
Thank you for re-confirming that. The Melling HD/HV is the only pump we use and sell so oil pump volume you should have should not be the problem from an oil pump issue.
Just to let you know we have a couple of customers running 750-800HP Whipple supercharged 496's that we built with thermostat oil cooler systems with coolers similar in size as yours and one is run at Havasu in over 110 degree temps for over three years now with lots of long distance and long duration blasts at 5000rpms and higher with no oil overheating issues so I know its quite doable and possible when everything is right. I stll believe your issue may be plumbing, routing or compnent issues in your oil filter and cooler system and not bearing clearances.
JMO
Best Regards,
Ray @ Raylar
Raylar is offline
Old 02-23-2012 | 10:54 PM
  #93
Originally Posted by Raylar
Rage:
JMO
Best Regards,
Ray @ Raylar
I agree but he won't post any pictures of the plumbing etc so someone else can see what he is seeing.
Pretty much a good stopping point until the engine comes out or someone else looks at it with another set of eyes preferably in person and not on the internet.
Then again, he wants to run wide open for at least 15 minutes. Everything has a limit. That's why I recommended buying a bone stock engine like the 525. It's made to run open all the time Just like the 500 EFI. But you can't hop those engines up to something more and run it the same as the way it was meant to run in the stock class race boats.. There is a TON of R&D that Merc puts into that kind of stuff.
Makes no sense to find another oil pan if it won't work on the block. Makes no sense to keep talking about it when there will be no engine removal very soon.
Go ride in the boat and have some fun. It will never be perfect. If you don't run it wide open for 15 minutes it may last longer and save some money.
The sure-fire way to settle it is to take the boat to a real mechanic and drop it off with an agreed budget (if applicable). They'll call you when it's right.
PS I'll send the larger version of the pdf asap.
SDFever is offline
Old 02-24-2012 | 07:03 AM
  #94
blue thunder's Avatar
The only way I have ever been able to run WOT as long as l wanted was when I did not run oil tsats (like kidnova suggested). The fact of the matter is the longer you run wot the more heat is built on a high perf engine. The only way to keep it under high level danger levels is to start with real cool temps like 140f or so. Then you have 100f to go in wot running just to get to 200f. If you run a 200f stat you only get 30f before danger. That's my experience on that. Or like sd says above, a low hp engine can do the same. For instance if rage were to put a 2 bbl carb on his engines he could probably run on wot all day and never have oil temp issues. The only other way would be with seriously large oil coolers. I think rage is asking too much out of his current system and there is nothing fundementally wrong with the build.
blue thunder is offline
Old 02-24-2012 | 09:59 AM
  #95
Rage's Avatar
Rage:
Thank you for re-confirming that. Your'e welcome.The Melling HD/HV is the only pump we use and sell so oil pump volume you should have should not be the problem from an oil pump issue. Good to hear
Just to let you know we have a couple of customers running 750-800HP Whipple supercharged 496's that we built with thermostat oil cooler systems with coolers similar in size as yours and one is run at Havasu in over 110 degree temps for over three years now with lots of long distance and long duration blasts at 5000rpms and higher That is great. I can run all day at 5000rpm with no oil over temp issues as well. Different HP of course. It is the extra HP from the 5600-5800 rpm WOT that over heats the oil. with no oil overheating issues What is their crank case oil temp during extended WOT running?so I know its quite doable and possible when everything is right. I stll believe your issue may be plumbing, routing or compnent issues in your oil filter and cooler system and not bearing clearances. In that regard you were nice enough to send me two 25 psi oil bypass valves gratis to replace the stock 11 psi oil bypass valves at the block filter adapter back in 2008 when I bought a lot of parts from you and built the current motor. Is there any way that those were not the 25 psi units and were 11 psi units?
JMO
Best Regards,
Ray @ Raylar
See above in red. Thanks.
Rage is offline
Old 02-24-2012 | 10:23 AM
  #96
Rage's Avatar
I agree but he won't post any pictures of the plumbing etc so someone else can see what he is seeing. Like I said before I am in Florida and the engine is in MO so I will be glad to when I get back.
Then again, he wants to run wide open for at least 15 minutes. Everything has a limit. Ray says that two Whippled 496 boats in Havasu can do it? That's why I recommended buying a bone stock engine like the 525. It's made to run open all the time Just like the 500 EFI. But you can't hop those engines up to something more and run it the same as the way it was meant to run in the stock class race boats.. There is a TON of R&D that Merc puts into that kind of stuff. Yep.
Makes no sense to find another oil pan if it won't work on the block. Correct, I never intended to use a wrong pan. Just posted to show that a pan could be equipped with a integral cooler which everyone said could not. Makes no sense to keep talking about it when there will be no engine removal very soon.
Go ride in the boat and have some fun. I do It will never be perfect. ProbablyIf you don't run it wide open for 15 minutes it may last longer and save some money.If I wanted to save money I would not have started down this road
The sure-fire way to settle it is to take the boat to a real mechanic and drop it off with an agreed budget (if applicable). They'll call you when it's right. That's no fun....for me anyway. Also a real mechanic ended up opening up the bearing clearances on twin Whippled 496 engines (731hp) with closed cooling and added external 15GPM oil pumps to finally get them to run unlimited time at WOT with no oil over heat problems. They use the identical oil cooler as I by the way. Of course this was also mentioned at the start of this thread.
PS I'll send the larger version of the pdf asap.I'm looking forward to seeing it. Thanks.
Please see above in red
Rage is offline
Old 02-24-2012 | 11:47 AM
  #97
Wink
We don't stock or use the 11 psi bypass vales, so I doubt it.
I prefer to look at your problem and solution in a simple three step investigation process.
One, take some pictures of your oil filter cooler system plumbing, fittings and parts and post those here or in PM so another set of eyes can review and see if there are any obvious or identifiable obvious possible issues or furthur questions.
Two, lay out a simple way to by-pass the thermostat for full oil flow not routing thru the oil thermostat.
Three if these don't find any causes or improvements, then the engine should come out and check by-passes for problems or to low pressure opening settings. Take pan off and look at clearances and conditions of bearings, etc.
I think the time, expense and difficulty of trying to come up with a possible over engineered bandaid solution like a crankcase cooler is impracticle and somewhat misguided.
Obviously there may be some days before you can get your Rage on the water and run these 15 minute WOT blasts, so there seems to be plenty of time to come up for yourself with a staged simple plan.
JMO,
Best Regards,
Ray @ Raylar
Raylar is offline
Old 02-24-2012 | 01:41 PM
  #98
Rage's Avatar
JMO,
Best Regards,
Ray @ Raylar
Thanks Ray I appreciate your honest input.
Bill
Rage is offline
Old 02-24-2012 | 02:04 PM
  #99
Not if its been covered but just throwing it out there...
http://www.offshoreonly.com/forums/g...-vi-502-a.html
post #26
ICDEDPPL is offline
Old 02-24-2012 | 11:57 PM
  #100
Rage's Avatar
Originally Posted by Philm
What are you calling excessive oil heat? is it hitting 300ºF?
Are you running the correct amount of oil? I ran to much oil at one point and the crank beat it up in the pan and made a bunch of heat. Dropped itdown to the correct level and the temps went back to normal.
10 qts is the spec. I tried 9 qts but no difference in crankcase oil temp.
Rage is offline
