how bad is this....
Picture is blurry but it looks like just a broken flapper to keep water out? If so that is an easy fix. You can get kits that have a new flapper and pin. Just grind/drill the old pin out and have the new one welded in place.
Is it the flapper? If so it looks like the rubber has worn off(holes showing on bottom portion and what looks like rubber peeling) so it would be a good idea to replace it anyway. May have lost the sprng and wedged itself somehow so it won't move? I'd check all the others as well.
I put Salisbury external flaps on mine. Not exactly "eye candy" but they don't blow out or fall apart.
Also you will have to unclamp/unhook the tip where it attaches to the tailpipe, header, riser depending on the exhaust system you have. Mine just has a rubber hose going from the header to the tip.
Here's some replacement options. Or you can just remove it and run the externals.
http://www.hardin-marine.com/c-1333-...-flappers.aspx
