496 manifolds >
496 manifolds
496 manifolds
Old 03-11-2012 | 10:04 AM
Fenderjack's Avatar
Pirate of the Chesapeake
Default 496 manifolds
Will 496 manifolds fit a gen 4 454 big block .Never paid much attention to the 496 heads. JOHN SR
Fenderjack is offline
Old 03-11-2012 | 10:14 AM
Yes they will fit. You will have to make some adjustments on some possible mounting brackets for remote oil filter and electrical relays and then check your riser heights as 496 risers come in different heights, 8" and 10". Many have made this conversion with great results. Stay away from the early 496 risers with lower seperate water rails as those did not last well and had some problems. The Later 2003 thru 2009 work well.
There are probably some OSO readers who will let you know exactly what they did and what years and model 454 setups they used them on.
Best Regards,
Ray @ Raylar
Raylar is offline
Old 03-11-2012 | 10:35 AM
i have risers $40 plus the ride each
mach1magnum is offline
Old 03-11-2012 | 01:20 PM
Best Regards,
Ray @ Raylar
can you visually tell the difference between the good and the not so good?
thanks
pqjack is offline
Old 03-11-2012 | 02:01 PM
i put them on my 454 remounted the oil filter and shifter bracket to the transom motor looks great
Old 03-11-2012 | 09:46 PM
This is the style you are looking for. I also made a bracket out of a couple pieces of aluminum "L" so the oil filter went back to it's original position.
This is my Mark IV 454 , stroked and rollered to a 496. With Merc 496 exhaust.
f_inscreenname is offline
Old 03-11-2012 | 11:00 PM
onesickpantera's Avatar
I think you have to drill the mounting holes in the 496 manifolds as they are metric and a few thousands smaller than the bolts used on the 454s.
onesickpantera is offline
Old 03-12-2012 | 07:43 AM
mine went right on no drilling had to get new bolts though
Old 03-12-2012 | 12:32 PM
Man that's a SMOKIN'n deal! Wish I needed them. Way cheap
SDFever is offline
