575sci rear oil draining....Great idea or Stupid idea ?? >
Old 03-13-2012 | 08:20 PM
Vinny P's Avatar
I hate the winter!!
Originally Posted by bob_t
For ~ $20 extra you can buy the power brake bleeder kit so you can bleed your brakes (or pull new clean fluid through the brake lines/brake cylinders/calipers) quickly and easily by yourself.
I second that. I use mine the same way. Since I figured that out some time ago, I threw away that P.O.S. Mighty Vac pump.
Vinny P is offline
Old 03-13-2012 | 10:34 PM
Are you guys using the manual one or the one that uses compressed air? I have been wanting to get one and wasn't sure which one to get.
I have a couple of buckets with the 12 V electric pump on top to pump out oil. They work pretty good for engine oil, but that's about it.
THanks, Eddie
Young Performance is offline
Old 03-14-2012 | 04:33 AM
THanks, Eddie
I use the manuel one because at my marina I have no access to a compresser........I would bet it is even easier with the compressed air, but the manuel unit works great.
Here's Johnny is offline
Old 03-14-2012 | 07:25 AM
i use the compressed air model in my shop...but i agree ,you gotta have access to a compressor
pqjack is offline
Old 03-14-2012 | 07:42 AM
88Fount33's Avatar
Beak botr
I use these quick connects on my engine oil drain hose attached to my oil pan. Have the 12v pump with fitting to pump into gallon jugs, warm oil flows best, but have to let it go lower than 180 degrees or it might hurt the pump internals. Been doing it since 2006 no problems with leaks yet.
88Fount33 is offline
Old 03-23-2012 | 04:55 AM
Due to limited space behind the blowers I had to modify my set up to drain the oil from the rear of the blower......here is what we came up with......this should do it........
Old 03-23-2012 | 05:03 AM
the quick release fitting should be sticking straight up just past the top of the blower......easy access and like was stated before, if the fitting/plug ever did come off or break the oil still wouldn't go any where......
I can use this to drain the reservoir and fill it too.......I will post in a few weeks how it works out.....
Old 03-23-2012 | 09:13 AM
Great idea. I like the updated version even better. Now go powder-coat it blue
RT930turbo is offline
Old 03-23-2012 | 09:25 AM
good idea.....think I am going to do that......
