View Poll Results: What RPM do you turn WOT
5000-5300
18
20.22%
5400-5700
22
24.72%
5800-6000
28
31.46%
6000-6500
21
23.60%
Voters: 89. You may not vote on this poll
WOT RPM, custom engines
I spin my 598ci N/A with a hydraulic setup to 6000rpm all the time, and would have no issues with going to 6200rpm if it was still making power that high.
It probably wouldnt live long at all if I threw a 36" prop on it and lugged it down to 5000-5200rpm. The heat in the chambers would lead to detonation, eventually getting everything so hot that the end result would be preignition, and I would wind up with an expensive paperweight.
So help me out here......and this may be more prop question than engine. My current engine has rev limiter set @ 5600 rpms....was stil make power all the way up till then but torque started to drop at 5300ish. My current prop i can only spin to 4900.....maybe 5000 if its over trimmed. This prop is in stock form. It doesnt make sense to me to be able to drop prop pitch and still be faster with a lower pitch prop but at only 4900 i am leaving 80+ hp on the table. Would i benefit from dropping pitch and running higher rpm?
Im guessing that if I posted this poll 15 years ago, we probably wouldnt see as many people turning 5600+rpm with pleasure boat engines. Seems that todays valvetrain technology opens things up a bit for us, campared to the old flat tappet hyd cams and light spring pressures.
i spin my 540,s in my cat to 6200 rpm,but normal crusing at 65 mph is around 3300 rpm,the nice thing is the way it accelerates from 60 mph on up,if i prop it to run 5200 rpm max,it is not getting to its max powerband and acceleration is poor at best,plus detonation risk increases from lugging .just my opinion,but it works for me!
Give us some details on the builds pete. Many mechanics are just that, mechanics. I'd listen to the builder on what's best for the engines.
