WOT RPM, custom engines >
View Poll Results: What RPM do you turn WOT
5000-5300
18
20.22%
5400-5700
22
24.72%
5800-6000
28
31.46%
6000-6500
21
23.60%
Voters: 89. You may not vote on this poll
Old 03-20-2012 | 11:22 AM
fireboatpilot's Avatar
RIPSTA Racing Team
Limiters have 6000 chips in them and I'm up on them alot spinning 36's. This year we'll be lowering the gears in the lowers to 1:36 instead if the 1:50 and reprop again! Still looking for more!
fireboatpilot is offline
Old 03-20-2012 | 11:23 AM
OldSchool's Avatar
Originally Posted by Philm
I spin my 598ci N/A with a hydraulic setup to 6000rpm all the time.
Me too..... Every time I go out at least once. Dart blocks, Callies cranks, Oliver rods, JE pistons with Isky ToolRoom springs, morel hyd roller lifters and AFR heads. Crane gold rockers and stud girdles on top.
95% of my time running is between 3500 to 4000RPMs.
5 seasons so far without having a valve cover off (knocking on my wooden desk as I type!!)
OldSchool is offline
Old 03-20-2012 | 11:45 AM
Originally Posted by MILD THUNDER
Dyno sheet, valve springs, cam specs, lifter style, cylinder head model, etc
on the dyno today. Not sure if he will give me cam specs since its custom.
drpete3 is offline
Old 03-20-2012 | 11:53 AM
if you paid for it, he should give you specs, maybe not every detail, but most!
Waveform is offline
Old 03-20-2012 | 12:25 PM
Airpacker's Avatar
I spin my blown efi 509 to 6000 regularly and for one particular poker run every year, I step down in prop for better acceleration as there is a very long, winding river on the run and spin it to 6200 to 6300 on the straights. Sure sounds nice up there.
Airpacker is offline
Old 03-20-2012 | 04:26 PM
The answer...it depends on the length of the stroke. The shorter the stroke, the more tolerant the BBC engine will be to increased RPM. Most of the Super Cat engines were 3.75 or 3.80 stroke and they raced at 7500 RPM...I think
BenPerfected is offline
Old 03-20-2012 | 05:15 PM
and yet we spend all kinds of time and money for the other 5 %
dereknkathy is offline
Old 03-20-2012 | 05:58 PM
Default fixx
Originally Posted by Baja_man
So help me out here......and this may be more prop question than engine. My current engine has rev limiter set @ 5600 rpms....was stil make power all the way up till then but torque started to drop at 5300ish. My current prop i can only spin to 4900.....maybe 5000 if its over trimmed. This prop is in stock form. It doesnt make sense to me to be able to drop prop pitch and still be faster with a lower pitch prop but at only 4900 i am leaving 80+ hp on the table. Would i benefit from dropping pitch and running higher rpm?
i would look into labbing your prop,you will pick up rpm just from that,,i picked up 600 when i did mine years ago but thats on a volvo ultra prop..
FIXX is offline
Old 03-20-2012 | 09:19 PM
600" N/A tunnel ram BBC - 6800 RPM
Solid roller!
WETTE VETTE is offline
Old 03-20-2012 | 10:03 PM
7,200 to 7,400.... 598s, 3.3 Whipples, Solid Roller! Had BPM 1.36 drives and 40 Pitch props. No more options at the time. Take out the chips and let her eat!!!
http://www.youtube.com/watch?v=dZz74XZnFUA
NOBODY is offline
