Adjusting the rev limiter??? >
Old 03-25-2012 | 05:10 PM
Default Adjusting the rev limiter???
I want to put my rev limiter a litle higher. The fire type is thunderbolt IV and is on a 525sc gen 6 engine and actualy the rev limiter is set at 5400 rpm.
Is that I need to replace the electronic module or I can reprogram and change the point of the rev limiter?
who can be reprogram this module?
supermx96 is offline
Old 03-25-2012 | 06:54 PM
The TB IV rev limiter is separate component and it cannot be adjusted. You will have to swith to an after market ignition box and rev limiter.
Part #41
http://www.mercruiserparts.com/Show_...CAL+COMPONENTS
Griff is offline
Old 03-25-2012 | 07:51 PM
Part #41
I make a mistake mine is not like this so i dont think it is a thunderbolt IV probably a newer version or a firepower type ing??.
If i can't reprogram the module what do you recomended for a good ignition box and rev limiter?
Mine is like that:
http://www.mercruiserparts.com/Show_...ru+0L415623%29
