Ignition pro's please respond >
Old 03-25-2012 | 06:55 PM
Default Ignition pro's please respond
Ive decided to build a 540 and will be running my m1 procharger at 5 psi on it. Which ignition systems do you guys recomend? i have a tb iv out of my 500 hp 454. but was thinking this is the way to go:
http://www.performancedistributors.com/marinedui.htm
zeke is offline
Old 03-25-2012 | 07:41 PM
waybomb's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Active Streak: 90 Days
Use what you have, but use the v6-14 module.
waybomb is offline
Old 03-26-2012 | 09:02 AM
whats the difference between that v6-14 and i think i have the v8-22? boats still in storage so i cant look yet
zeke is offline
Old 03-26-2012 | 09:32 AM
waybomb's Avatar
You will get about 18-19 degrees module advance, so you can set your initial timing at 12 or so.
Easier starts.
waybomb is offline
Old 03-26-2012 | 09:41 AM
Biggus's Avatar
Easier starts.
Sorry, not to offend waybomb, but not true.
I'm a big fan of the V6 module (V6-14) because of its short curve, but keep in mind, it's designed for 6 cyls and advances 14 degrees only when installed on a V6.
The V6-14 module starts advancing at 650 rpm and only provides 8-10 degrees of advance when mounted on a V8.
If using the V6 module, set your total timing first and let the initial timing fall where it may. I had my old blower motors set at 28 degrees, at 1000-1100 rpm idle the initial was 20-22 degrees.
They do work very well and are incredibly reliable and cheap.
Kurt
Biggus is offline
Old 03-26-2012 | 10:13 AM
v8 HP module starts @ 1500 and totals out @ 3000 It has a 20 advance .
Rockfish71 is offline
Old 03-26-2012 | 10:54 AM
waybomb's Avatar
Kurt
Oops,yup, you are correct. I always set mytiming at full advance since my engines do not idle at 600, and the modules have an error of +/-2 degrees. I run 30.
waybomb is offline
Old 03-27-2012 | 07:15 AM
I run a 509 with a procharger, use a MSD dist w/a digital 7 box, advance locked, box has a 20 deg start retard and triggers for water injection and dial rev limiter...way overkill but I had most of it...works great..
ezstriper is offline
