496 ho side exhuast >
496 ho side exhuast
496 ho side exhuast
Old 03-29-2012 | 05:01 PM
Default 496 ho side exhuast
Buddy wants to remove the baffels on his side exhaust.
Where are they located? I've only removed them on transom exhaust.
TIA
cabin fever is offline
Old 03-29-2012 | 09:46 PM
Default fixx
TIA
most likely they have mufflers in the exhaust pipe going to them.you will have to look inside the exhaust tips and tubes to figur out where they are.
FIXX is offline
Old 03-30-2012 | 07:49 AM
Knot 4 Me's Avatar
TIA
What boat is it? If it is a Corsa system, like mine, the baffles are welded into the stainless elbow that makes the 90 degree turn towards the side of the hull. Make sure you do not remove the flappers built into the hull-side exhaust exit.
Knot 4 Me is offline
Old 03-30-2012 | 08:25 AM
Thanks. Yep its a corsa system. Will make sure we leave the flappers in. Thanks again.
