Hole saw size
Always go with the smaller size first. You can always open the hole up with some sort of sander/grinder, or large half round file if you need a little more clearance. I personally think that hole saws always end up cutting a little bigger than advertised anyway sir.
If you already have a hole there... it is more difficult to use a hole saw again unless you make a plug or something to center the bit. I would draw out your new circle and then die-grinder to it with a large sanding drum. Take your time and mask off the gel coat outside of your cut so that you don't chip it.
I would make a plug; and affix it to a small piece of plywood bigger than the plug itself.. Then attach the plywood to the inside of the transom with a couple of temporary screws. Going backwards on the holesaw works pretty well, but do yourself a favor and invest in a NICE holesaw and strong arbor. The cheap stuff they sell at the box stores is worthless for a boat transom.
When I need to enlarge an existing hole, I put one hole saw inside of the other. Put the 4.5" hole saw on the arbor, then screw on the 4". The 4" will hang farther out and act as a guide as you drill through the transom. I use it on exhaust holes, gauge holes, etc. It just has to be a big enough jump in sizes so the smaller one fits inside of the larger one. Usually 1/2" is enough to clear.
Eddie
Eddie
