-   -   Wrenches are a flying!! Water in Oil! Help!! (https://www.offshoreonly.com/forums/general-q/273725-wrenches-flying-water-oil-help.html)
38tg 04-11-2012 07:56 PM
did you use valley gaskets with the intakes ? i made that mistake once.
obnoxus 04-11-2012 09:42 PM
I would run a tap into the bolt holes as well
MILD THUNDER 04-11-2012 09:56 PM
Originally Posted by obnoxus (Post 3661624)
i would run a tap into the bolt holes as well
+1
HiMark Racing 04-12-2012 12:01 PM
Yup, did that also..
My brain is cooked..Spent a whole day yesterday pulling all the studs..cleaning out threads, sealing..everything done right..filled system with water and pressure tested.. and I still have a LEAK!!! Nothing changed..leaks down just as fast..I hear nothing..see nothing..I left the blower off and valve covers off to see if I see a leak..nothing!! 13 days and counting...:readinghelp:
vette131 04-12-2012 02:00 PM
try pressure testing it with the distributor out & use a borescope or a mirror to look under the intake for a leak.
HiMark Racing 04-12-2012 05:08 PM
We think a like..did that..no leak there..
I pulled the heads off and sent them to shop to get pressure tested.
HiMark Racing 04-12-2012 05:11 PM
Nope..used "The right stuff". When I pulled the intake off this last time..RTV was pressured equal also on all 4 ports.
mike tkach 04-12-2012 08:06 PM
to bad you live so far away,i have a 1000 hp engine sitting in the shop you could use for havazoo.
HiMark Racing 04-13-2012 11:42 PM
Update: 3" crack in one of the heads. 12 days till Havasu. Find out Monday if repairable. RHS heads. Less than 30 hrs on them. Never overheated. Not like!!
SFOcean 04-13-2012 11:53 PM
At least it is not the block; hope it is easily repairable!
