intakes on hp500's >
intakes on hp500's
intakes on hp500's
Old 04-10-2012 | 12:18 PM
For GM heads Dart has a special intake. You put GM after the part number. These intakes are milled .060" from the factory.
cstraub is offline
Old 04-10-2012 | 11:24 PM
try sitting the manifold on with out any gasket and check to see how the bolt holes & ports aline up make shure that the intake is not resting on the china walls .if the bolt holes aline up have the manifold milled .060
protechcoat is offline
Old 04-10-2012 | 11:30 PM
try that
Old 04-13-2012 | 11:52 AM
Default intakes
thanks everyone for you're input on this problem, i have it pretty well figured out thanks to the information i received on this site.
jackieboy is offline
