sealing k-plane indicator cables
I removed the k-planes from my boat to repaint the transom plate on each k-plane. I removed the indicator cable pass through fitting that screws into the k-plane transom bracket. When I want to re-install the k-planes with new indicator cables, do I need to put some sort of sealant on the threads of this fitting? I know there is a nut that screws on top of this that compresses a compression ftting around the cable, but I guess I also have to make sure the threaded fitting that screws into the k-plane bracket is also sealed. Just wondering what I should use? Telflon tape?
Eddie
Rookie, you can get them from Van's Sport Center right here in GR. The rubber part and plastic are cheap, the stainless part not. I have the part numbers written somewhere so I don't have to go through the "I'm not seeing it on the computer screen here..." speech every time I go in there! Nick
