650HP Small Block! >
650HP Small Block!
650HP Small Block!
Old 06-26-2002 | 11:53 AM
Iggy's Avatar
Default 650HP Small Block!
In this months issue of Hot Rod magazine they show a 357ci small block that'll rev to 8k rpm. Max hp (652.3) is at 7K and max torque (507.4) is at 6100 rpm.
All built with used NASCAR parts.
Muscle Motorsports is a dealer of used Winston Cup parts and sells to the general public. They are currently starting to sell complete engines set up for hot street use. All components are as close to current race technology as you can get. Even the splayed valve GM SB2 heads are available.
Blocks (SB2) come in dry and wet sump versions.
Compression ratio is not 13:1 but 10:1 and still pump out 650hp.
The cams are custom grind Comp Cams roller type for street use.
Valve train is full race 8k rpm capable.
Wouldn't that make a screaming SBC powered ride?
The price is on the steep side but worth the bragging rights.
Iggy is offline
Old 06-26-2002 | 12:19 PM
Iggy's Avatar
I guess I should've listed what parts went into it.
Displacement: 357.08ci
Compression: 10:1
Block: GM SB2 Bow Tie, cast iron
Heads: GM SB2 aliminum splayed-valve
Crank: Bryant billet, 3.340 in. stroke
Rods: Carillo 6.200 in.
Pistons: CP, 4.125 in. dished
Cam: Comp Cams roller
Lifters: Comp Cams roller
Rockers: Jesel shaft-mounted roller
Pushrods: Comp Cams 3/4 4340 steel
Valves: Del West Titanium, 2.15/1.600
Intake: GM open-plenum ported by Wilson
Carb: Holley 750
Iggy is offline
Old 06-26-2002 | 12:53 PM
CigDaze's Avatar
That's pretty impressive Iggy.
Thanks for posting that. It would really make for a bad-azz street ride.
CigDaze is offline
Old 06-26-2002 | 01:54 PM
jr
I wonder if my alphas could handle that...hmmmmm.
I do have a couple of bowtie 400 blocks currently in use. Naaaaa. I think my wife would kill me. She almost did over the last SBC's I build.
Old 06-26-2002 | 02:21 PM
Scott72
A friend of mine is having triple 600 HP. small blocks built for an ex offshore boat (40' Activator) he picked up. Given they are blown, but should be an interesting ride.
Scott
Old 06-26-2002 | 11:53 PM
Ummmmmmm sign me up for two!!!
pullmytrigger is offline
Old 06-27-2002 | 06:40 AM
Iggy's Avatar
At a price close to 12K each you could by two new Merc engines with drives.
Iggy is offline
scorpion king
6
06-30-2007 09:18 AM
handfulz28
10-15-2006 02:25 PM
DKerns
5
09-05-2006 01:40 PM
chriscraft240
4
08-28-2003 01:17 PM
Da Patriot
44
11-24-2002 08:27 AM
