big block chevy heads compare
have a set of 14097088 rec port big block chevy heads 2.19 1.88 open 118. was wondering what the specs are on a ls6 big block head. i have a set of these also
because if they were i could use them for my future twin engine build. thanks
They made 2 dfferent LS6 heads. 1970 was a closed chamber rec port with 109cc chamber and 1971 was a open chamber rec port with 118cc chamber. Keep in mind the LS6 heads were on MK IV's and the 088's are Gen V up so you need the correct head gasket depending on the blocks you will be using.
