power steering leak >
power steering leak
power steering leak
Old 05-11-2012 | 11:39 PM
Default power steering leak
my power steering pump is leaking where the line from the bottle comes in, it was fine last weekend and i just checked everything again and had fluid in the bilge, thought maybe the clamp split the hose so i cut the end off and its still doing it no matter how tight i clamp it on, i just installed imco add-on steering and everything else is good, only difference is i bought power steering fluid from parts store, would this have any effect? it is coming out between the hose and nipple base of pump
blownhammer2000 is offline
Old 05-12-2012 | 08:04 AM
Mine did that on my 496 PS pump last year. If you's is like mine there is a 90 deg elbow where it enters the pump, between the line and the pump. That elbow has a very small plug in it, looks lke a small freeze plug. It was corooded and needed replaced. Easy job once you remove the pump.
NightHawk is offline
Old 05-12-2012 | 09:20 AM
there is no 90* elbow, the fitting is direct to pump, it almost looks like the nipple is pressed into the pump body and that is where it is leaking, i can't imagine that its cracked but i'm starting to think it might be, never had a hose that would not seal around a fitting with a clamp
Old 05-12-2012 | 12:56 PM
Default fixx
if its plastic you can replace just the tank,,2000 pont grand prix has the same tank..if its the metal one then its brazed to the tank,,remove the pump,,clean the oil out with solvent and have ir brazed back up..
FIXX is offline
Old 05-12-2012 | 09:13 PM
ok, took the boat out today and checked the bilge and fluid level all day and it was perfect, not a drop, yet i cleaned fluid out of the bilge just before we dropped in, like it seals up when its warm??? now what? i'll check in the morning to see if its back leaking again, pretty sure it will be
fixxall-the tank feeds the pump from a remote location, no tank on pump itself, and its leaking where the rubber hose feed the top of the pump
Old 05-13-2012 | 11:47 PM
Default fixx
does the hose attach to a bango fitting?
FIXX is offline
Old 05-14-2012 | 08:02 PM
bango fitting??? sorry but i don't know what that is
Old 05-14-2012 | 09:30 PM
the deep's Avatar
Fast Singles Club
Veteran: National Guard
Banjo fitting . http://www.google.com/aclk?sa=L&ai=C...itting&cad=rja
the deep is offline
Old 05-14-2012 | 09:41 PM
thanks sam, def not that, its just a standard flaired nipple
Old 05-14-2012 | 10:15 PM
the deep's Avatar
Fast Singles Club
Did you find more fluid in the bilge after it cooled ? Are you sure your not just seeing residual fluid from installing your steering ?
the deep is offline
