Mechanical Drive Gauge >
Old 05-18-2012 | 11:03 AM
Default Mechanical Drive Gauge
I turned on one battery on my 292 Fastech in the driveway and went to put up my drives up and found that only one went up. I slewed it down and turned on both batteries thinking this was the culprit. Then hit the drive button and both came up and went down. The problem is the drive gauge now doesn't work for the drive that sat the first time around. It worked fine last season and the cables appear fine. What did I do? How do I reset? Thanks ahead for any advice.
pondrunner is offline
Old 05-18-2012 | 11:24 AM
The plunger actuator on the drive is probably just stuck from sitting all winter.
Griff is offline
