what causes a new ign module to go out? >
Old 05-29-2012 | 03:47 PM
Ted G's Avatar
Originally Posted by Airpacker
Good idea Ted but, I would suggest the better way to test the ground is to use a volt meter while the engine is running and check between the distributor and block and the block and ignition module.
Any more than 100 milivolts, under 50 would be preferable and I would be cleaning up grounds. Far more accurate than using an ohm meter.
You're right, I was sleepy last night.
www.cbpba.com
Ted G is offline
Old 05-30-2012 | 09:21 AM
Something that is most often forgotten is that the tach wiring could cause problems ;-)
Alex is offline
