Blower belt questions >
Old 07-01-2002 | 06:57 AM
Biggus's Avatar
Default Blower belt questions
I`ve got 671`s with Superchillers and the belts are rather long and are becoming a pain in the butt to keep in check.
My idler/tensioner pulley is pushing on the outside of the belt and seems to loosen under hard running. I see many that have the idler on the inside of the belt pushing outward.
What works best??
Thanks, Kurt.
Biggus is offline
Old 07-01-2002 | 07:51 AM
Mbam's Avatar
Offshoreonly Advertiser
Kurt, we have used both ways. The idler should be on the slack side of the belt, not the tension side.
Mbam is offline
Old 07-01-2002 | 07:58 PM
birdog's Avatar
Let me ad another Question
How tight should they be ? Mine seem awful loose but they are both that way and they work.....A couple of inches slack in them.
birdog is offline
Old 07-01-2002 | 08:37 PM
Mbam's Avatar
As the engine warms up the belts will get tighter, so check them hot. I run them with 0 slack, no tension but no slack. You can double check by turning the blower pulley, there should be no movement. Try loosening and tightning the belt until you get a feel for it. Too loose will actually increase the side load on the shafts due to the tooth profile, too tight will break something as the belts have 0 give in them.
Mbam is offline
Old 07-01-2002 | 08:42 PM
birdog's Avatar
Thanks Marc........
Mine must be WAY loose....I will adjust them!!!!
birdog is offline
Old 07-01-2002 | 10:25 PM
Biggus's Avatar
I just got back in from running the belts with the tensioner pushing outward and could not believe how much louder the belt whine was as opposed to the tensioner pushing inward.
Is it because of the toothed belt/smooth pulley?
Thanks for the input,
Kurt.
Biggus is offline
Old 07-01-2002 | 11:16 PM
Mbam's Avatar
That would make sense, I never did a back to back test.
Mbam is offline
ciaoderhead
19
07-09-2008 07:57 PM
BraceYourself
5
04-10-2008 06:37 AM
ghittner
0
04-23-2007 06:18 PM
iamfaster
9
10-26-2006 09:16 PM
duunoit
1
06-28-2004 12:57 PM
