dry risers thru the transom. pros and cons >
Old 05-31-2012 | 02:49 PM
Default dry risers thru the transom. pros and cons
wondering if there is any advantages or disadvantages of running long dry risers thru the transom . i know my cams are border line for reversion so i dont want any problems. i know on the dry the water doesnt mix untill the end but will this make the risers hot or increase temp inside engine compartment. its a twin bigblock setup
hjalmerroe is offline
Old 05-31-2012 | 03:27 PM
What are the specs on your cam? Risers that dump the water at the end are dry to the tip, a true dry riser will dump the water out of a completely different location. As for there being heat issues- NO! They are water cooled the entire length so there is no issue with extra heat. One thing to remember a true dry riser is LOUD!
endeavour32 is offline
Old 05-31-2012 | 03:35 PM
What he said.
MILD THUNDER is offline
Old 05-31-2012 | 03:41 PM
PatriYacht's Avatar
Loud enough to make your head hurt. Plan on getting mufflers of some sort also.
PatriYacht is offline
