looking for speed >
looking for speed
looking for speed
Old 06-12-2012 | 07:50 PM
Originally Posted by 01scarab29
hey guys ,,, have a little information, 2001 29ft scarab, twin 5.7's, bravo 1's, mirage plus 23's, 100gal tank,,, 2 people, 3/4 tank fuel, 4900rpm, wind just right 68mph GPS,,, run 65mph easily,,, I cruise 4000rpm, 55mph,,, been told PowerTech props are a very good choice, talked with them and was told they wouldn't change anything,,, said i'm buying spare set anyway what would you suggest ,,, they ask how it plans out, told them fine, it sometime trys to blow out, but very seldom he suggested OFX 3 blade 24p props ,,,,, wondering about 25p or OFX4 blade ,,, would like some input from ya'll ,, i know cars but just starting with boats
This is about how my boat runs. I think once you gain some experience with it, youll figure it out, then you can start playing in modding it out. As I stated before, I'm in the same boat (just a different hull).
Shag555 is offline
Old 06-13-2012 | 10:30 AM
fireboatpilot's Avatar
RIPSTA Racing Team
Get in touch with BBlades and try their prop enchange program. Every boat hull and power combination reacts differently, even boats made by the same manufactures same size etc. Every boater carries different loads, hulls aren't exactly the same, hooks etc. so every boat needs to be dialed in with the right props. Even then you need to find a happy medium to a point to adjust for top speed, getting on plane etc.. You need to know what max rpms are for your engines and cruise should be aprox. 75% of that. Question is, can you reach max rpm or do you exceed max rpm under normal WOT conditions? Can't reach, too much prop. Exceed, not enough. Roughly 200-250rpm for each degree of pitch up or down is a good rule of thumb. I'm far from an expert and I'm sure there are others on here that can give better advice. This is my 2cts worth and what I have learned. The more information you have on hp, rpms, load etc can help you get a starting point and go from there.
fireboatpilot is offline
Old 06-13-2012 | 09:59 PM
thanks fireboatpilot, information will be remembered and used,,, max for my engines are 5000, your factors tell me 3750 is cruise, i did run an hour stretch with a few bigger and faster boats,,, my cruise was 3700- 4000 .... sometimes 3700-3800 sometimes 4000 back to 3900 and so on .... the boat did feel and sound comfortable their...... in your opinion, where is the most economical place to gain torque ?
01scarab29 is offline
Old 06-18-2012 | 10:35 AM
Default performance
has anyone ever heard of or used Dyno-Boost Boat Performance Chip
Old 06-18-2012 | 11:01 AM
Yeah, about $3.00 worth af radio shack parts soldered into a crappy case. If you would like to purchase a Flux Capacitior from me I have one for sale. Once you hit 88 MPH, you will beat everyone to the dock
Sorry, that was a bit sarcastic.... IT is a total Scam.
low_psi is offline
