502 Low Oil Shutdown? >
Old 06-10-2012 | 11:04 PM
Default 502 Low Oil Shutdown?
Do stock 502's have a low oil shutoff? I had a remote oil line rupture while running around 3200rpm and the engine cutoff. No alarms or high temps were shown. Dipstick shows no oil.
Rcolter is offline
Old 06-10-2012 | 11:32 PM
No, it just sets off the alarm.
Griff is offline
Old 06-11-2012 | 07:56 AM
Does it crank over? Hopefully you didnt lock it up.
MILD THUNDER is offline
Old 06-11-2012 | 03:35 PM
Rookie's Avatar
I lost an oil filter at 5000RPM (I believe sabotage). The low oil alarm went off and I immediately shut it down. Next day filled it back up with oil, ran it on the hose for a bit, pulled the oil filter off and cut it open. All looked clean and ran it for another 4 years.
I hope you are as lucky.
Rookie is offline
Old 06-11-2012 | 08:28 PM
No alarms went off. Didn't notice or hear any noise other than engine shut off.
Engine turns over so not sure extent of damage. Good thing it had less than 5 hrs on it from rebuild last year.
Rcolter is offline
