msd coil compatible with stock system need help >
Old 06-11-2012 | 04:40 PM
Default msd coil compatible with stock system need help
burning up ign module sensors inside the distributor.
called msd they said and alot of you said it might not be compatible with the stock mercury thunderbolt iv ign
MSD needs to know what ohms my stock coil is suppose to be at then they said they will know if there msd high vibration coil will work.
does anyone know what a stock coil on a 454 330hp motor should ohm out at?? thanks
mookster is offline
Old 06-12-2012 | 04:43 PM
don't know the ohms, but have seen certain coils not work with certain ignitions...several of MSD coils are ignition specific
ezstriper is offline
Old 06-12-2012 | 05:07 PM
You may need a ballist resistor in the line. I tried A blaster coil with a points dist. without a resistor and the points lasted about a minute before they turned blue and pitted.
fbc25el is offline
Old 06-12-2012 | 07:46 PM
got off the phone today with msd they said they are compatable (coils)
mookster is offline
Old 06-12-2012 | 09:25 PM
i checkd one today,11.1 ohms.
mike tkach is offline
Old 06-12-2012 | 10:49 PM
Why not just get a Merc coil and be done with it???? I had an MSD coil go bad after 2 years on my Pantera. I put a 10 year old Merc coil on it and it was still working fine.
Griff is offline
Old 06-13-2012 | 12:44 AM
i got over 20 yrs on my mallory pro coil..if you remember super shops way back when,,thats where i got t from..
FIXX is offline
