hour  meter  stoped working? >
Old 06-21-2012 | 08:51 PM
26sonic's Avatar
Default hour meter stoped working?
one of my hr meters has suddenly stopped working? checked to see if maybe a wire fell off but ok. is there a fuse for each meter on a twin engine set up???
26sonic is offline
Old 06-21-2012 | 09:01 PM
replace it........
Centsless is offline
Old 06-21-2012 | 09:17 PM
Cool, that engine will never wear out
Seriously, there should be 12 volts going to it with the switches on. If you have the 12 volts and it still doesnt work, it is probably bad. If the two meters are close enough together in the panel you could also swap the wires from the working one to the non-working one and see what happens. If it starts to work, you can be pretty sure the meter is bad.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
BillK is offline
Old 06-22-2012 | 05:00 AM
why worry? now that engine will never wear out...
dereknkathy is offline
