Yellow stained bottem hull help? >
Old 07-04-2012 | 12:37 AM
Originally Posted by buckknekkid
Oxalic Acid, most shops in Fla use it.
This is what FSR is.
Trash is offline
Old 07-04-2012 | 08:09 AM
Elite Marine's Avatar
Thats what the Works is too. And its cheap, fast and available anywhere.
Elite Marine is offline
Old 07-04-2012 | 09:54 AM
Originally Posted by jim66
Sno-bowl toilet cleaner...put in a spray bottle, spray on hose off then rewax. It also removes stains from bolts, good stuff and cheap!
Glad I ran into this thread.. I've been using On/Off and that stuff works, but is dayumn killer if it hits your skin or you breath it in. Just ordered some Power One
sleev-les is offline
Old 07-04-2012 | 11:09 AM
Where do you find Oxalic Acid?
Thanks,
Padraig is offline
Old 07-05-2012 | 08:54 AM
J.B. Marshall's Avatar
JB Marshall
I have found Crystal Lakes hull cleaner to work extremely well. I mix it in a pump spray bottle, spray in on wait 2 minutes brush it in and spray it off and back to to white again.
J.B. Marshall is offline
Old 07-05-2012 | 08:58 AM
FSR (Fiberglass Stain Remover)
Wipe on, sits for a couple minutes and rinse off. Done.
You watch the yellow turn white while you wait. Amazing stuff.
242LS is offline
Old 07-05-2012 | 09:18 AM
I have used most of the ones listed but stick to FSR now... it doesn't seem as strong as the rest but because it is a Gel it sticks to the hull and slowly works. Because it isn't as strong the bottom doesn't get yellow again right away like some of the other cleaners that seem to microscopically damage the gel coat.
VetteLT193 is offline
Old 07-05-2012 | 07:13 PM
tomtbone1993's Avatar
Agree looking for some different options as well.
tomtbone1993 is offline
