454 Mag. getting hot, HELP >
Old 07-01-2012 | 09:12 AM
Default 454 Mag. getting hot, HELP
1994 454 Merc. mag, carbed. Not used often, so new impeler, new circ. water pump.
On hose, water flow seems a bit low, but water si coming out whre it should, at STD or a bit higher RPM's. Engine gets to about 175-180+-.
Possible restriction in water lines due to age? or thermostat?
I wouldn't think it would get hot just on idle, and didn't take i tout for sea tret yet.
Any ideas? Thx
P
PARADOX is offline
Old 07-01-2012 | 02:39 PM
take inlet hose off sea pump. stick garden hose in and blow out back thru drive or transom pick-up. especially if it is a drive pick up. the fitting in transom where both hoses mount is the skinny spot and stuff can back up there.
dereknkathy is offline
Old 07-01-2012 | 06:03 PM
Done that. Thanks. no ristriction in any "rubber" hose. Possibly in the block, rust? corrosion? etc? but I welcome all ideas.
Thx
P
PARADOX is offline
Old 07-01-2012 | 08:11 PM
MOP
Lightbulb
Risers!
MOP is offline
Old 07-02-2012 | 07:59 AM
you cannot get normal waterflow on the garden hose,anything above idle and the sea pump will suck more volume than the garden hose can supply,put it in the water and il bet it will be ok.let us know the outcome.
mike tkach is offline
Old 07-02-2012 | 08:54 AM
obnoxus's Avatar
Charter Member #1171
WHAT HE SAID !!!!!!!!!!
If you have a sea strainer take a look at it,,,,,,its always empty on a hose,,,,not enough volume
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
