How do I tighten my Merc Single lever conmtrol? feels loose >
Old 07-16-2012 | 11:02 PM
Question How do I tighten my Merc Single lever conmtrol? feels loose
Throttle/Shift control lever on my 1990 boat feels loose.
Took the little trim cover that holds the trim and trailer buttons, but i don't see anything. On the backside, I can feel it, but can\t see anything, without taking out some interior parts.
How do I tighten it??
I have read one post that sounds like this might be the answer?? (I'm 2 hours away from the boat, so can't try it yet)
"remove the button by shifting forward with button depressed and take a small screw driver to remove then spray some lube back there works sometimes if not remove control box and you'll see what needs to be lube
first step will be remove handle which is 9/16 nut behind button"
2Slow4me is offline
Old 07-17-2012 | 08:10 AM
jjj
I have a merc single lever also (merc 3000 ?), I think there is an allen head screw on the bottom of the fixed portion of the the throttle/shifter to make adjustments.
jjj is offline
Old 07-17-2012 | 10:25 AM
Knot 4 Me's Avatar
Does your controller look like this --> http://www.mercruiserparts.com/Show_...REMOTE+CONTROL
Or this --> http://www.mercruiserparts.com/Show_...A+1+%2D+A11%29
Knot 4 Me is offline
Old 07-17-2012 | 11:27 AM
jjj
Looks like the second one
jjj is offline
Old 07-17-2012 | 12:34 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
item #22 says 'friction'. I'd take a look into that.
Handle feels loose as in falling off, or doesn't stay in position?
US1 Fountain is offline
Old 07-17-2012 | 12:53 PM
Then to tighten the handle you need to push in item number 6, Go to WOT, Pry out button, Go back to neutral, Tighten item number 7 using a long 11/16 socket with an extension, tighten to 150 inch pounds or 12.5 foot pounds what ever smaller torque wrench you have should do. Then install the botton while still in neutral. Then test to ensure the button pops back out a few times.
If you don't go to WOT, You will break the button while prying it out, The button comes out pretty easy once you get a small bladed screw driver behind the button.
lakematdude is offline
Old 07-17-2012 | 05:27 PM
Default More like the second one
Mine, the handle where you grip is flat rectangualar, not as molded looking as the one in the diagram.
Looks like this one:
http://www.mercruiserparts.com/Show_...E+CONTROL+ASSY
or this one:
http://www.mercruiserparts.com/Show_...L%29+VERSION+1
2Slow4me is offline
Old 07-19-2012 | 08:07 AM
Question How do I tighten my throttle?
I see the previous answer for a similar throttle control, but would really appreicate any input on my model.
Heading up this weekend, and would love to get it done.
Thanks in advance!
2Slow4me is offline
Old 07-22-2012 | 11:51 PM
Thumbs up
Got it done ! Really easy. Just a set skrew under the handle at an angle. You need a mirror to see it. And an Allan wrench
2Slow4me is offline
