How much fuel do you really have in the tank??
Wondering how accurate everyone's fuel gauges are?
My scarab has a single 130 gallon tank. The pickups and the sender are located at the rear of the tank. Between the sender being at the rear plus the angle in which my scarab sits in the water my fuel gauge reads full when there is about 60 gallons in the tank. And then the gauge falls aggressively as I burn fuel again because of the angle. Is this something everyone gets used to or is there more then one sender in other tanks and you average the readings?
Maybe this is normal?
Jim
Jim
What you also have to take into consideration is that most tanks have angled bottoms mirroring the inside of the hull bottom. That means that most tanks (mine is one)only carry approx. 30 - 40% of the fuel in the bottom 1/2 of the tank and 60% - 70% in the top half which has straight/square walls.
I ran my old Sonic out of gas several times until realizing this. Always seemed to do good on the 1st 1/2 tank and the gauge was validating this. Once you dropped bellow the 1/2 mark on the gauge the needle dropped twice as fast from there down.
That angle in the bottom of the tank was causing this.
I also just finished experimenting with sending units. Replaced the OEM version w/a Livorsi floatless version. Measure difference of ohm readings of an empty tube submerged in tank. It quit working (was a $100. TOO!) @ 30 hrs (more Livorsi garbage!) and just got replaced by the version w/a round float n a similar tube. No mechanical linkage to adjust and has far lees needle bounce.
Sorry for the book but been there, done that.
I have twin 130 gallon tanks. When the gauge reads 1/2 tank, I have about 50 gallons left.
Ive been chasing this since I bought my Hustler 3 yrs ago. Ran out on a Poker Run, still hear about it from the boat club!
I have had 3 different senders in the tank. Finally on the Moeller unit with the donut style float. At least it will tell me when I am almost out. It did the same as described above.
I filled the boat for the last run and have fuel flow gaue on boat so I know exactly what I burned.
Boat holds 135 gallons, I burned 76 gallons yet the gauge reads 3/4 full still.
Im going to burn off another 25 gallons which should leave me with a quarter tank. I'll then mark the gauge. Dont know what else to do.
Youd think there would be a better way and a lot more accurate!
I own these senders in both of my boats and they work excellent but they don't fix the issue I talked about initially. It doesn't have so much to do with the sender as it does simply with the shape and attitude of boat fuel tanks.
http://www.centroidproducts.com/
Well I feel a little better that it's not only me!
I suppose a second sender mounted mid tank would help to show fuel consumption above the 60 gallon mark. In theory if calibrated correctly the first sender would report 1/4 tank when the second sender would start to show movement off of the full mark
My fountain stays on full along time and then drops to a half . When it hits a quarter look for gas it only last about 10 miles. I know for sure ran out a mile from the dock and I was down river from the dock it sucks.
