breaking up / missing ? >
Old 07-26-2012 | 06:48 PM
Angry breaking up / missing ?
I have been reading on here for a while but i have to ask for a little help.
Boat is a 98 Baja Outlaw 454 MAG MPI with a procharger aprox 500hrs
The issue i'm having is a weird miss. sounds like its breaking up. It does it under varying conditions. that's what puzzles me. It sometimes breaks up while accelerating from idle, if i pull the throttle back and then blast it full throttle the boat will jump up on plane run a few second then break up again. so it would suffice to say it does it all different times.
I keep thinking its ignition. Did plugs, wires, coil, cap and rotor. needed it anyway no change. changed the fuel filter/sep just in case. not water in it. while doing the cap and rotor noticed some corrosion in the distributor so i sprayed it with some electric contact cleaner.
any help would be greatly appreciated. i'm getting frustrated with this thing.
meansvt00 is offline
Old 07-26-2012 | 07:03 PM
Could be a loose rocker arm as well. Timing could be off in valve train.
GTOFFSHORE is offline
Old 07-26-2012 | 07:15 PM
articfriends's Avatar
Whats the fuel pressure doing when this happens?
articfriends is offline
Old 07-26-2012 | 08:19 PM
the pressure was steady at 38 while running and would rise under boost condition.
i just went out to re verify after changing the fuel filter th epressure is low now approximately 18psi.
i bought the boat with this setup. does anyone know the fuel system routing with the procharger setup. is the factory pump retained.
there is a extra fuel pump and regulator mounted by the filter. im going to check the actual piping in he morning.
Old 07-27-2012 | 07:33 PM
cant get the fuel pressure to go over 18psi messed with the regulator no change. pinched the return line no change.
maybe a bad pump
Old 07-27-2012 | 10:37 PM
Default fixx
maybe a bad pump
i most likely have a bad fuel pump, DONT RUN THE BOAT LIKE THIS you will blow the engine up..could be tha fuel pressure regulator but doutful,,looks like one of thease..could be seperate or a cool anodised one like in the pic's..http://images.google.com/search?num=...ac.fkdeL6wLmc8
you chould have 38 psi at idle then when you throttle up 1 lb of fuel pressure per every pound of boost so 43 ish under boost...
FIXX is offline
