Whippled 496HO running hot >
Old 08-14-2012 | 02:18 PM
Rwbrew3's Avatar
Originally Posted by 28Eliminator
The 496 is closed cooling and what the Whipple instructions say to use. The 502 side mount kit says to remove the thermostat. The only real difference the 120 would make is maybe give more restriction and cause more water pressure, but no real reason to run it unless you are in cold water a lot.
Appreciate the feed back, no cold water here in Texas!!
Rick
Rwbrew3 is offline
