Warning Alarm Help?? >
Old 08-07-2012 | 09:24 AM
Default Warning Alarm Help??
I was wondering if anyone could point me in the right direction on a warning alarm issue I'm having. I'm getting a warning tone on startup that lasts about 45 seconds and then fizzles out. It can't be an overheat issue because its at startup. My oil level is good and I'm getting water pressure. Does anyone know where else I should look?
TC G is offline
Old 08-07-2012 | 09:34 AM
Did you check the gear lube level when cold?
BenPerfected is offline
Old 08-07-2012 | 09:37 AM
I did not. I will do that. Thanks
TC G is offline
Old 08-08-2012 | 11:39 AM
What is the best way to check that?
TC G is offline
Old 08-08-2012 | 04:14 PM
Assuming you have a Bravo drive, there should be a reservoir on the inside of transom. It it is 1/2 full cold, this would say the gear lube is not causing the alarm unless the sender is defective. If it is low, add gear lube as noted on the bottle.
