Outdrive lube >
Outdrive lube
Outdrive lube
Old 07-08-2002 | 06:13 PM
Default Outdrive lube
What is the best outdrive lube to use? I have been considering Redline Shockproof.
onesloryd is offline
Old 07-08-2002 | 10:24 PM
MIKEHTMSR24's Avatar
Default torco RTF
Imco said they switched from Royal Purple to Torco in their race boat and liked it better. They said they didn't like redline as well. They said merc, redline royal purple and torco were all good oils for recreational boats.
they said they run their boat at 6100 to 6200.
MIKEHTMSR24 is offline
Old 07-09-2002 | 09:43 AM
patrick22309
Was using Shockproof and had no shavings. I destroyed drive on rock and merc dealer said what is this red stuff? I said shockproof. He said, "You don't want to run that." and he filled it with Merc HP when repairs done. I went home and changed back to shock proof. Shockproof is very thick, so it be easier on the gears when I am plowing out of my shallow ass marina.
Old 07-09-2002 | 03:51 PM
NObaja
been using hipo merc (the green stuff) on a 1989 drive.
I'm very hard on my boat. Last year I hit a log and broke the ring and housing on the transom unit. I had the drive torn down for inpection, and was told to put it back together and run it another thousand hours!
boatman22
Drives and Lower Units
3
08-16-2008 09:22 AM
allenk4
11
08-08-2007 08:25 PM
382 newbie
17
11-06-2006 09:04 AM
Katt Nipp
8
09-28-2006 07:42 AM
turbo2256
5
04-18-2002 12:54 AM
