changing exhaust, what shifter bracket is needed? >
Old 08-20-2012 | 10:01 AM
Default changing exhaust, what shifter bracket is needed?
I'm changing my exhaust on my 502 from the fractory cast iron exhaust to the mercruiser/ gill alum center rise exhaust. On my iron set up the shifter mechanism was bolted to the exhaust itself. On the new exhaust system I need the shifter bracket adaptor.
Is shifter barcket part number 8M0052632 the correct bracket?
crf311 is offline
Old 08-20-2012 | 11:45 AM
You can just screw the shifter bracket to the transom.
Griff is offline
Old 08-20-2012 | 02:38 PM
Really, How would I do the lay out? Does anyone have a picture of doing it this way.?
crf311 is offline
Old 03-21-2015 | 08:53 PM
Bump?
Cole2534 is offline
Old 03-21-2015 | 11:55 PM
Originally Posted by Cole2534
Bump?
What do you want to know??? You just screw the stock shifter linkage assembly to the transom in a place that it fits and so the cables don't have sharp bends.
[ATTACH=CONFIG]538850[/ATTACH]
Attached Thumbnails changing exhaust, what shifter bracket is needed?-525sc.2.jpg
Griff is offline
Old 03-22-2015 | 07:26 AM
the 70's version had a bracket stuck up from the top 2 flywheel cover bolts. mounted right behind distributor. would be easy to make and probably could be found on ebay. similar location to griff's pic above. although griff's location makes more sense. if you have to mess with the engine, why mess with shift cables and risk changing adjustments? it was mounted to exhaust for convenience of the factory installation.
dereknkathy is offline
Old 03-22-2015 | 08:30 AM
Griff, I'm not familiar with the cable routing, didn't totally get the way all three cables interacted. Got it now, thanks.
Cole2534 is offline
